throttle body check engine code
Old Jun 16, 2022 | 01:47 PM
kathummer2025's Avatar
Angry throttle body check engine code
Hi! I have a 2007 hummer H3 with only 44,189 miles. I've been having engine issues and after spending 5,000$ trying to fix it I've become a bit desperate. When turning my car on I've been it's been "cranking with no start" and will after turn off. This issue will happen then disappear for a bit and then come back up. The throttle body has been replaced twice and it's still having this issue. I am waiting on the exact code from the service tech, but I am getting very anxious and wondering if anyone else has experienced this and can possible help shed some light on what we can do to fix her, i appreciate any and all help!
Old Jun 16, 2022 | 01:55 PM
What did you get for $5,000?
Old Jun 16, 2022 | 03:06 PM
Then we know it is not the Throttle Body................. unless your Tech used an el cheapo off brand as a replacement.
Anyways, we need the code(s).
Old Jun 17, 2022 | 07:28 AM
Default P2101
That's what I wanna figure out haha :/ the code is P2101!
Old Jun 17, 2022 | 07:29 AM
I think it's been an accumulation of overall work like oil changes, throttle body replacement twice, new tires and am waiting for the documents to be sent over, but the current code it's reading is P2101
Old Jun 17, 2022 | 08:56 AM
Are you still trying to use the crappy azzed OEM Battery Terminal Connectors? If so, hack them off and replace with an aftermarket set like Stingers or your favorite brand. The FIRST mod to be done to every H3/H3T to correct a known failure point.
Check voltage at fuse #46, if there's a drop, check/swap relay #81 & #71.
DesertDog
56
May 5, 2018 05:57 AM
pikappapp
Dec 24, 2017 12:19 PM
shobi
Aug 28, 2017 04:13 PM
alishapeaches
Dec 12, 2015 11:53 AM
whitesmoke
Jun 24, 2014 09:52 PM
