Tcc code???
Old Aug 26, 2019 | 08:13 AM
Fambam's Avatar
Default Tcc code???
Few weeks ago got a check engine light on and it gave me the tcc stuck code so i bought the selonoid and the on/off switch drove it for like 3 weeks and now my check engine light is on but now i got the temp sensor code and tcc stuck off code what could it be since i alrady replaced both tcc sensors ? Can i still drive it like this has no effect drives the same help......
Old Aug 26, 2019 | 12:56 PM
Check coolant in the radiator for contamination.
Old Aug 26, 2019 | 04:19 PM
Fambam's Avatar
Hmmm ok i will what should i look for oil??
Old Aug 26, 2019 | 05:02 PM
No, Gremlins.
Seriously, you post your issue, and want help, yet do not post the codes?
Since, I can not see your H3 in person, I gave you a basic check(common issue), after that, I would need the codes, or you can take it to an auto repair shop and have them replace the transmission, engine, pcm, etc..=Big $$$$$$$$$$$$$ Wasted!
Old Aug 26, 2019 | 06:49 PM
Fambam's Avatar
P0741 tcc solenoid circuit performance or stuck off
Old Aug 26, 2019 | 07:25 PM
With an ECT sensor code?
Old Aug 26, 2019 | 10:20 PM
Fambam's Avatar
I bouth the cooling temp sensor and installed it and reset the computer hopefully doesnt pop up anymore but i dont think that ect sensor has anything to do with the tcc code coming on its two completely diffrent things idk.....
Old Aug 27, 2019 | 08:16 AM
Pray tell.... what is the temp sensor code????
Old Aug 27, 2019 | 09:46 AM
What causes the P0741 code?
  • Faulty TCC
  • Faulty torque converter lockup solenoid
  • Internal short in the TCC solenoid
  • Wiring to the TCC solenoid that is damaged
  • Faulty valve body
  • Faulty Transmission Control Module (TCM)
  • Faulty Engine Coolant Temperature (ECT) sensor
  • Damage of the wiring harness to the transmission
  • Restricted hydraulic passages from dirty transmission fluid
Old Aug 27, 2019 | 10:35 PM
Fambam's Avatar
Ect code p0117 short circuit
Hooty-Hoo
Jan 2, 2015 06:54 PM
barry4x
18
Dec 19, 2014 04:57 PM
nolo91
Feb 19, 2014 04:12 PM
dunringil
Apr 4, 2009 06:14 PM
azz7772
Jan 10, 2008 10:03 AM
