Sunroof won’t open makes noise
Old Jul 23, 2018 | 06:23 PM
Gomer's Avatar
Try this it is a switch relearn procedure see if it helps.
1. Turn the ignition to ON.
2. Completely close the sunroof window with the manual close switch.
3. Press the sunroof vent switch to the vent open position until the sunroof window stops,and continue holding the switch for at least 10 seconds.
Old Jul 25, 2018 | 01:49 PM
SlcHummer's Avatar
I'd hope this isn't the case but I once read a forum reply where the owner was going to "permanently lock and seal" their sunroof because of the notorious sun roof drain issues. This seems like a lot more work than just fixing the known issues with the sunroof drains lol. I would inspect the sunroof to ensure the previous owner didn't do something like this.
Old Jul 25, 2018 | 07:28 PM
Chimpy's Avatar
I unplugged power to the sunroof in my 2006. I waited about 5 minutes and plugged back in to power. This is when I depressed the vent button and held it until it was in re-learn mode. It has worked fine ever since. I bought my 2006 used, right after winter. My theory is that the PO tried to open the sunroof with ice on it. This can get them out of sync.
Old Jul 28, 2018 | 10:35 PM
Roo817's Avatar
Default Had it checked
Had some local sunroof repair guy inspect it and he said the rails and everything is good, the motor is good BUT the plastic spinning gear wheel is bad and when we press the sunroof open or close button the motor engages but plastic gear stops easily when you put your finger on it it doesn’t keep spinning. Any help? Would I just have to buy the whole motor assembly?
Old Aug 1, 2018 | 11:06 PM
hummer_on_fumes's Avatar
there's 1 on eBay but it's $50
Old Aug 2, 2018 | 12:03 PM
Gomer's Avatar
Get the specs on it and see if someone can 3D print it for ya..
Old Aug 4, 2018 | 01:29 PM
Roo817's Avatar
Default Ordered a new motor
The old motor worked but the white spinning wheel inside it would stop just by putting your finger on it, had a dude inspect the whole roof rails and all that and he determined the motor was bad found a lexus motor that’s a defect fit for 50$ on eBay so I’m trying this I’ll keep you updated
Old Aug 6, 2018 | 11:32 AM
Post the Lexus part # if it fits and works flawlessly please.
Old Aug 11, 2018 | 11:43 PM
Roo817's Avatar
Default Fixed it!
the part # is AISIN 63260-48060 the new one had the plastic wheel and motor working but the board was bad so I swapped the boards and it worked!
Old Aug 13, 2018 | 07:06 AM
The AISIN 63260-48060 fits and runs with NO modifications to wiring or mounting points?
Vents the roof, full open, closes automatically?
