Steering shaft not right
Old Aug 16, 2025 | 08:09 AM
Fordpinto1*'s Avatar
Default Steering shaft not right
Hello, I have had a 2008 H3 come in the shop. Steering shafts where upper and lower connect is not right. Very loose. All looks new. I contacted the owner and they said they just had another shop replace it with parts from eBay. So I don’t know if they installed the wrong parts,something is broke or the cheap eBay part is just poorly made. I would like to use GM parts but not sure if spending all that money will get me the same results the last shop got. Thanks
Old Aug 16, 2025 | 12:50 PM
maybe the upper steering shaft column bearing has play.
Old Aug 16, 2025 | 03:29 PM
Thank but no it is where the pinch bolt hold the two together. Tight as can be but still loose.
Old Aug 16, 2025 | 07:17 PM
Only 1 way to connect fit the steering shafts together from rack to column! Post a picture of your issue.
MyDirtyH3
May 10, 2021 04:37 PM
BeachReadyAutoRepair
Jan 29, 2021 12:49 PM
NateGr8
May 6, 2020 09:36 PM
balbright
Aug 28, 2010 08:28 PM
hummerbee
17
Sep 9, 2007 07:55 PM
