Steering Column Replacement...
Old Apr 17, 2020 | 04:13 PM
NateGr8's Avatar
Post Steering Column Replacement...
I need my steering shaft replaced and my mechanic said it would end up being a better price if I get a salvage steering column and replaced the whole thing instead of paying him the time of taking apart the steering column, so my question is can I get a steering column from a different year or would they be dramatically different.
Thanks!
Nate
Old Apr 17, 2020 | 09:36 PM
Find a new mechanic, or better, research steering shafts replacement and diy.
Old Apr 18, 2020 | 05:41 AM
LatvjuAvs's Avatar
Steering column or steering shaft(and there are two shafts)?
Why do you need to replace it?
Old Apr 25, 2020 | 06:58 AM
NateGr8's Avatar
The upper shaft and lower shaft are both rusted out and not secure.
Old Apr 26, 2020 | 03:58 PM
LatvjuAvs's Avatar
All H3's have same shafts, there was improvements after year 2007, if you go for originals.
Do it yourself! Lift front up a little bit, get rid of front left wheel and remove inner wheel plastic, remove bottom shield and go for it!
Do not forget to lock your steering wheel. Use tape, bands, special tools, whatever.
Old Apr 26, 2020 | 08:42 PM
Btw, you don't get the needed steering shafts with a used H3 steering column.
Look here for more info: steering shafts
Old May 6, 2020 | 04:24 PM
H3Luxembourg's Avatar
Oh a good old and helpful treat, thanks for digging this one out.
Old May 6, 2020 | 09:36 PM
I know like the back of my hand. Still tight and drives like new.
DougH2
Jul 12, 2017 08:04 PM
quadblaster240
Mar 30, 2012 07:48 PM
ava327
Aug 10, 2011 02:48 PM
jmamadog
Apr 5, 2011 05:27 PM
eight_bit_micro
Oct 12, 2008 08:53 PM
