Stability/Traction Control
Old Jan 4, 2020 | 11:47 PM
BamaH3's Avatar
Default Stability/Traction Control
Turn this off when cruising highway speeds in dry weather?
Old Jan 5, 2020 | 09:25 AM
No need to do that.
Old Jan 5, 2020 | 09:31 AM
BamaH3's Avatar
No need to do that.
why not? and if not,whats the point of it? reading the owners manual makes no sense about it
Old Jan 5, 2020 | 01:20 PM
The system operates only if it senses that any of the wheels are spinning or beginning to lose traction. The traction control system automatically comes on whenever you start your vehicle. To limit wheel spin, especially in slippery road conditions, you should always leave the system on. If you press and hold the TC button for five seconds, the traction control system will turn off and a TRAC OFF message will appear on the DIC. StabiliTrak activates when the computer senses a discrepancy between your intended path and the direction the vehicle is actually traveling.StabiliTrak selectively applies braking pressure at any one of the vehicle’s brakes to assist the driver with keeping the vehicle on the intended path. If you press and hold the TC button for five seconds, the StabiliTrak system and the traction control system will turn off. When this is done, the STAB SYS OFF message will be displayed on the DIC.
Old Jan 6, 2020 | 08:07 AM
StabiliTrack is what makes the H3 near idiot proof when driving and it does nothing until you NEED it.
TC is turned off with a press of the button. StabiliTrack is turned off by holding the button for a few seconds.
The only time you want to turn that off is when in deep sand, tires deflated to appx 11-15 PSI so you can use unfettered momentum to climb dunes and allow some tire spin.
Attached Thumbnails Stability/Traction Control-dsc00897.jpg
Tim Brown
Dec 3, 2016 05:01 PM
Det2008SUT
Apr 29, 2013 09:19 AM
H3girl1
Aug 22, 2012 08:47 AM
XxCC3xX
Aug 20, 2011 02:30 PM
hynesinkc
33
Jan 6, 2008 10:53 AM
