squeaky rear door handle
Old Oct 5, 2022 | 05:26 PM
Justinh's Avatar
Default squeaky rear door handle
When the left-rear door handle is fully pulled out it squeaks. I sprayed lubricant in the rearward hole but no change. Any idea exactly what is squeaking and how much disassembly is required to fix it?
Old Oct 6, 2022 | 08:30 AM
Spray the front pivot then get back with us.
Removal/replacement is super easy, like a 1.5 of 10. Pull it off and spray a lubricant (NOT a solvent).
Old Oct 8, 2022 | 02:02 PM
Justinh's Avatar
Thanks for that. I hit that handle hard but could still not get it to pop out, so I couldn't lube the front hinge point. I really think the squeak is coming from the spring mechanism at the rear. I could barely see it with the rear cover off. I think I got spray lube on it but it is no better. Maybe I need a diff kind of lube (I used silicone spray).
Old Oct 11, 2022 | 06:06 PM
Justinh's Avatar
Don't know what changed, other than time, but today I used the door several times and did not hear a squeak. Maybe it just took time for the lube to go where it needed to go.
Old Oct 11, 2022 | 06:43 PM
Relative humidity?
Old Oct 12, 2022 | 08:25 AM
Justinh's Avatar
I don't think that is the case, but I think the humidity is expected to go back up during the next few days then back down, so we'll see.
Rogcapital
Dec 10, 2021 11:07 AM
ski.dive
Aug 19, 2019 04:16 PM
Chimpy
May 7, 2017 09:19 PM
mrjohnp
Nov 10, 2013 03:56 AM
parabat
Oct 10, 2011 11:09 PM
