some type of fumes coming into the cabin
Old Jul 15, 2023 | 12:44 PM
Eurynomestolas's Avatar
Default some type of fumes coming into the cabin
When i accelerate going on the highway ramp i get some fumes into the cabin idk what exactly it is. I just want to figure out how to fix it. I am going to recheck the exhaust manifold. Maybe add some lock tight to the bolts. I know they always come loose but any other ideas where this could he coming from?
Old Jul 15, 2023 | 04:48 PM
OEM exhaust manifold bolts break, I upgraded to Class 12.9 studs 9yrs ago, never a problem since!
Old Jul 16, 2023 | 09:08 AM
Justinh's Avatar
Can you see the fumes? What do they smell like?
Too bad the pics were lost in Hummerz upgrade post.
Old Jul 16, 2023 | 09:32 AM
no cant see the fumes.
Old Jul 16, 2023 | 01:05 PM
@hummerz do you think this is the only spot the issue could be from? i am going to add some blue locktite to the bolts see if that helps
Old Jul 16, 2023 | 01:44 PM
Check the flange connection where the exhaust system connects to the manifold. Also could be a crack in the manifold? Look for any trace of black carbon, or have someone hold a rag on the tailpipe and listen for a leak.
Old Jul 16, 2023 | 07:20 PM
is the smell coming from the drivers side rear passenger area? does it smell like fuel? the top of your fuel pump might be rotted out. and if it is then really inspect your break lines as they might also be compromised.
Old Jul 16, 2023 | 10:25 PM
not fuel. its like exhaust/carbon smell. hapoens when i punch the pedal to the floor
Old Jul 17, 2023 | 10:45 PM
Disel's Avatar
many options. bad manifold gasket, burst manifold (common problem). oil escapes from under the valve covers and enters the manifold. All this can be checked with a smoke generator. where is the leak. On a cold engine, this may not be, only on a hot one it will appear.
KU1525
Jun 18, 2021 10:56 AM
LennyLexx
Jun 30, 2017 06:46 AM
OneBigHummer
Jun 12, 2014 10:05 AM
travieso
Apr 16, 2014 10:34 AM
lex
Nov 14, 2012 11:29 AM
