Some light bulbs out
Old May 1, 2020 | 11:46 AM
650Hawk's Avatar
I don't think that the mirror control has a light, does it?
Old Dec 28, 2021 | 10:28 AM
Mytruck09h3talpha's Avatar
Default Bulbs
Originally Posted by Cohiba54
Yep thanks bulbs are on the way and YouTube is a big help
The bulbs i got from ebay are not correct even though it said they fit 2009 h3t alpha. Anyone have an accurate source for replacement bulbs ? The Chevy dealer just said they are not serviceable and i need to replace the door swich panel. Thanks
Old Dec 28, 2021 | 01:33 PM
So they fit everybody's H3/H3T but yours? A T4/T4.2 bulb is a T4/T4.2 bulb, they come in different colors and, if LED they ARE polarity sensitive so they have to be put in in the correct direction (you have a 50/50 shot, if they do not work at first, remove, rotate 180 degrees, try again).
Chevy dealers are full of chit.
Old Dec 28, 2021 | 11:58 PM
wrong, the bulbs i got from ebay do not fit and i am well aware of the bulbs specs but thanks for typing it twice. The gm part number is what I am after if anyone knows it, I would appreciate it. Thanks in advance. ps, my experience with Chevy dealers has been excellent across the board .
Old Dec 29, 2021 | 06:33 AM
GM does not list a P/N for the bulb. You have to buy the entire assembly of which the bulbs are out.
Bought these and fit perfectly in the climate control and door switch assemblies. NOT LED.
Amazon Amazon
Old Dec 29, 2021 | 01:35 PM
I just pulled 1 on my oe master switch and it measures 10mm base.
Old Dec 29, 2021 | 02:00 PM
Also, the access hole is 11mm diameter on the switch.
Old Dec 30, 2021 | 09:00 AM
There could be an issue with the cheap Chinese junk on ebay no doubt, but I can assure you T4/T4.2 bulbs do indeed fit
Old Dec 30, 2021 | 07:18 PM
Mike2008's Avatar
Just replaced two bulbs on the climate control module. I used the cciyu 20 piece warm white T4/4.2 Neo wedge halogen bulbs. Ordered them from amazon.
