Some light bulbs out
Old Aug 20, 2019 | 01:27 PM
Cohiba54's Avatar
Default Some light bulbs out
I’ve got several interior light bulbs that need to be replaced. See pics. Plus the front passenger and rear window switch are not lit. Should the be?
How do you get to the bulbs to replace them?
Old Aug 21, 2019 | 09:53 AM
they are soldered on to the boards. it involves disassembling all those things.
WRONG about the H3 once again! They are screw in bulbs.
Amazon Amazon
Originally Posted by choochmalooch
I just replaced mine 2 weeks ago. Bought the bulbs on eBay real cheap. Probably takes about 30 minutes tops. Pulling the dash plate off is real easy. Getting the control housing apart is the biggest pain but there's a YouTube video out there where a girl uses guitar picks to separate the housing, it's real helpful. You can also use thin washers as I did. I recommend replacing them all while you're in there.
https://www.youtube.com/watch?v=lI6X3JcFMjE
Old Aug 21, 2019 | 10:50 AM
Cohiba54's Avatar
Glad you chimed in Tainter. My soldering is getting harder and harder to do neatly these days and thanks for the amazon and youtube links. Pretty sure I can handle it now.
That little gal know her stuff.
Old Aug 21, 2019 | 11:16 AM
Cohiba54's Avatar
Tainter
Do you know if the same bulbs fit the window switches and the front and rear differential lock displays?
Old Aug 22, 2019 | 12:45 PM
Originally Posted by Cohiba54
Tainter
Should be the exact same bulb.
Don't forget to remove the little blue condom off of each bulb and reuse it on the new ones.
If you don't the brightness will be different.
Old Aug 22, 2019 | 01:18 PM
Cohiba54's Avatar
Tainter you do know there are cretin things men don't talk about or do together. Sorry I couldn't resist... But yeah will do on the little blue condemns.... thanks.
Old Aug 26, 2019 | 03:24 PM
choochmalooch's Avatar
Cool
The bulbs are cheap and there's plenty of YouTube videos on how to do it.
Old Aug 26, 2019 | 10:26 PM
Cohiba54's Avatar
Yep thanks bulbs are on the way and YouTube is a big help
Old Mar 28, 2020 | 08:20 AM
Stellabarbara's Avatar
Does the 2009 H3 have a light bulb in the front passenger window switch?
Old Apr 27, 2020 | 06:15 AM
My 2009 H3 has a bulb in the passenger switch but I can’t get it to work. I guess I need to replace the switch.
