Running Wires into the cab
Old Sep 18, 2020 | 07:37 PM
dcr465's Avatar
Default Running Wires into the cab
06 H3 (pause for groans) I have two aux lights, grms radio power & antenna, and ham radio antenna I need to run into my cab. Could some PLEASE point me to the best spot to run these. Being morbidly stupid I'm going to need pics or instructions. Thanks in advance!!!
Old Sep 22, 2020 | 04:46 PM
Justinh's Avatar
Sorry - no pics. I drilled a hole in the upper-left portion of the driver-side firewall and used a grommet. Sometimes you can find an existing grommet or plug you can pass thru a small diameter wire, so look around the desired proximity.
Old Sep 22, 2020 | 06:45 PM
dcr465's Avatar
Thanks!!!!
Old Sep 23, 2020 | 06:18 AM
GrampaEJ's Avatar
While investigate possible locations, pay close attention to any nearby moving parts, and/or HOT parts.
Use plenty of zip ties to prevent your wires from vibrating, and getting chafed, also.
EJ
Old Sep 23, 2020 | 08:28 AM
dcr465's Avatar
Thankyou very much. I've been playing with using the hole where much of the wiring goes thru the firewall. It's located near the brake master cylinder. I have some plastic conduit to keep separated from other wires. I don't think I be able to get everything thru there so I'm looking for a 2nd site also.
Old Sep 25, 2020 | 08:55 AM
These pix should help.
I used a step drill for the appropriate size
Amazon Amazon
I used a daystar firewall grommet
Amazon Amazon
Old Sep 26, 2020 | 08:40 AM
Justinh's Avatar
That about says it all...
That is an awesome grommet.
Old Sep 26, 2020 | 10:42 AM
wpage's Avatar
Default Truth
[Well Done....
QUOTE=TAINTER;377893]These pix should help.
Amazon Amazon
Amazon Amazon
[/QUOTE]
Old Sep 26, 2020 | 02:14 PM
dcr465's Avatar
Yep!!! Even a old, slow Hoosier like myself can follow these pics!!!
Selandbe
Dec 18, 2014 08:51 AM
kauaineb
Oct 24, 2011 03:43 PM
superfly
Sep 11, 2010 01:22 PM
robertrh
Apr 8, 2010 09:05 PM
SafariHummerH2
Jul 9, 2008 03:40 AM
