Roof Marker Light 'RIV NUTS' ==How do you get them out?
Old Jan 24, 2020 | 09:50 AM
ski.dive's Avatar
Default Roof Marker Light 'RIV NUTS' ==How do you get them out?
Do they just unscrew or do you grind them off?
Old Jan 24, 2020 | 12:48 PM
brothapig's Avatar
If they are true riv-nuts, and the same style used in aviation, you drill the top flange off, then using a punch push them through the back. Same as removing a rivet.
Old Jan 24, 2020 | 03:05 PM
They are not a rivet, they are a rivet nut or for short rivnut.
"A rivet nut, also known as a blind rivet nut, or rivnut, is a one-piece internally threaded and counterbored tubular rivet that can be anchored entirely from one side. It is a kind of threaded insert."
Unless stripped or the mounting surface is cracked, you unscrew a rivnut to remove it. If when you try to unscrew it it does not loosen, then you have to drill them out. If lucky, they may pull out if the mounting surface is badly damaged.
There are some threads here regarding them, problems associated with the roof marker light use, and roof rack rail use of them as well. Pics in this thread. H3 leaking without a sunroof
Old May 25, 2020 | 11:47 AM
zefrum's Avatar
Im not aure why the recommendation from everyone i’ve heard from is to drill them out; but what I can tell this forum is get the M6-1.0 mandrel for a rivnut install tool and re work the installed rivnut by threading the mandrel through the nut and squeezing the handle hard.
Ive actually got a lot of experience with rivnuts, aluminum and steel, and its not rocket surgery, so im curious why no else has recommended this as a fix.
Full disclosure I have yet todo this repair on my truck, but I am nearly certain itll work
Old May 25, 2020 | 01:41 PM
Broken Halo's Avatar
You've got the right idea. Drilling it out is a last resort. If you've got the right mandrel and tool, chances are good you'll be able to tighten it.
Old May 26, 2020 | 12:01 PM
zefrum's Avatar
I have the Marson RN-1, which us just a single handed setter. But checking the the M6.0-1 mandrel is $25 after shipping (no Amazon) https://www.blindrivetsupply.com/Mar...10_p_1427.html.
For less than double that single mandrle you can get the double handed setter and a whole range of mandrels, including the M6.0-1 for the roof marker rivnut, for $48 from Amazon
https://www.amazon.com/gp/product/B07MVXN7LK/ref=ox_sc_act_title_1?smid=A1FS8W6H9OOIF2&psc=1 https://www.amazon.com/gp/product/B07MVXN7LK/ref=ox_sc_act_title_1?smid=A1FS8W6H9OOIF2&psc=1
When I get it Ill post my results.
duffy2092
Jan 7, 2014 04:06 PM
googie714
Oct 6, 2012 08:32 AM
Davidh3
Jul 30, 2011 09:24 AM
NCALPHADOG
Jan 30, 2010 07:21 PM
mgurgone
Jun 23, 2007 12:30 PM
