H3 leaking without a sunroof
Old Nov 19, 2017 | 08:41 PM
BoldBostonBabe's Avatar
Default H3 leaking without a sunroof
Hello, I'm new to this site and have an issue I haven't seen addressed anywhere else yet. I have an 08 H3, NO sunroof, and it's started leaking on the drivers side, down through the door (maybe?) and down inside where the seat belt retracts into. I've seen lots of threads on clogged drainage tubes for folks with sunroofs, but I do not have a sunroof....so...? Also, it's all original equipment, including original windshield and no leaks around dash or floorboard, I have no clue where this is coming from. Any help would be appreciated. Thanks in advance!
Old Nov 20, 2017 | 05:35 AM
BruceS's Avatar
Are you missing one of the bolts that holds the trim on the roof or cargo track? Could also be one of the rivnut for same on roof leaking.
Old Nov 20, 2017 | 07:21 AM
X2 on a stripped leaking rivnut
Old Nov 21, 2017 | 07:41 PM
I don't think I'm missing any bolts on the roof. But I will certainly check that out, thank you. This is a new problem, I had zero issues in CO, but now up in WA it's rainy and it leaks, ugh. It also now has a hell of a vibration-I'm thinking a broken motor mount? Looking for someone up here that will take a look without the dealership (labor-intensive) rates!
Old Nov 24, 2017 | 06:54 PM
Blacksky's Avatar
X3 on the possible rivnut issue.
You will need to completely remove the roof rails and plastic moldings to see if the rivnuts have fatigued.
If they have, and you have any weight on the roof, it will definitely cause vibrations.
Unfortunately I've had the experience.
Attached Thumbnails H3 leaking without a sunroof-rivnut-fatigue-1.jpg   H3 leaking without a sunroof-rivnut-fatigue-2.jpg
Old Nov 27, 2017 | 04:18 PM
Happy Hummer's Avatar
Wow!
Well that just sucks. How did you fix that issue?
Chris
Old Nov 27, 2017 | 04:45 PM
Blacksky's Avatar
Crash repairer glued a full length metal strip on top and put in new rivnuts. I also got him to insert extra rivnuts in between the original ones.
Unfortunately I did not get any photos before the plastic mouldings were reinstalled.
Old Dec 11, 2017 | 07:51 PM
jorallo's Avatar
Smile wow i have to now do this thank you so much !!!
my 09 h3 with major leaks
my youtube video
second video
i will check my riv. nuts on the roof this weekend.. but being in florida this is not good it rains and we have hurricanes, however my roof liners are not wet nor are they stained.. if anyone else wants to reply here or on my youtube channel go for it.
- thanks again!
Old Jan 5, 2018 | 05:19 PM
Blacksky's Avatar
Hey BoldBostonBabe,
Did you get your leaking and vibration issues diagnosed and fixed?
Any feedback would be good.
swampdawg
Aug 25, 2013 12:50 PM
derf911
Jul 24, 2011 01:31 PM
scared2buy
52
Jun 18, 2010 12:12 AM
firehawk24
Sep 1, 2008 05:32 PM
Trey124
19
Jun 7, 2007 08:21 PM
