leaking sunroof
Old Aug 24, 2013 | 02:04 PM
swampdawg's Avatar
Default leaking sunroof
I recently bought a 2007 H3 with a sunroof. It has been raining for days and the floor on the passenger side has water in it. I took a compressed air hose aand inserted into front drain holes to see if the drain hose was blocked. When I hit the air it sounds as if it is blowing out from the engine compartment near the wiper cowling. any thoughts to what's going on? How do I find where the drains empty out?
Old Aug 24, 2013 | 02:43 PM
egroegart's Avatar
Do a search on this site and you will find your answer
Old Aug 25, 2013 | 12:50 PM
dan perez's Avatar
Sounds about right., The drain on the pass. side is about two inches below the place where the dash and windshield meet. The pass. side is an easy fix, see the previous posting on the repair for detailed information. Oh., and using compressed air is just a Band-Aid, you really need to remove the rubber fitting and open the hole up by removing the rubber blockage. Good luck, Dan
derf911
Jul 24, 2011 01:31 PM
scared2buy
52
Jun 18, 2010 12:12 AM
firehawk24
Sep 1, 2008 05:32 PM
Trey124
19
Jun 7, 2007 08:21 PM
H34 pleasure
44
May 4, 2007 04:17 AM
