Odometer and trip odometer stops
Old Mar 4, 2020 | 03:21 PM
big.paolo's Avatar
Default Odometer and trip odometer stops
Hy to all of you.
Tofay i ritired my H3 from the mechanic and the odometer is stop and it doresn’t continue to count the km and the trip odometer is stop on 0.0 km too.
what can be?
what can i tell him to check?
because i need the car and i can’t wait their time...
thanks a lot for your sure help!
Paolo
Old Mar 4, 2020 | 03:49 PM
Scan and post diagnostic trouble codes. P0502?
Old Mar 4, 2020 | 11:40 PM
big.paolo's Avatar
Hy,
NO diagnostic trouble codes are shown in the scan tool
NO mil is on.
ALL the other intruments are going well
It’s all right with the car, the only problem is that the odometer and tip odometer are stop, the first on the total km and the second on 0.0 km.
the mechanic has disconnect the battery for some days to make her job (change head valves).
any help is appreciated
thanks
Paolo
Old Mar 4, 2020 | 11:49 PM
big.paolo's Avatar
Cruise control is OK
speedometer is OK
all other instruments are OK
only odometers stop
my 2007 Hummer H3 is 3.7
Old Mar 5, 2020 | 09:16 AM
Did you have the cluster replaced? Was it with a used cluster?
If so, the used cluster Odometer will not work until it reads the same mileage/KM as the vehicle it was removed from.
example.
Original cluster mileage: 44,000 miles
Used cluster mileage: 55,000 miles
The used cluster will not move until your vehicle reaches 55,000 miles.
Old Mar 5, 2020 | 02:11 PM
big.paolo's Avatar
[QUOTE=TAINTER;371299]Did you have the cluster replaced? Was it with a used cluster?
example.
The used cluster will not move until your vehicle reaches 55,000 miles.[/QUOTE
NO.
As i wrote before i don’t change anything on my H3. The mechanic changed only the valves,
what i can do or tell him to do?
can i update the software or something else?
thanks
Paolo
Old Mar 5, 2020 | 02:40 PM
You can replace your instrument cluster.
Old Mar 6, 2020 | 07:11 AM
Broken Halo's Avatar
example.
Old Mar 6, 2020 | 07:53 AM
Originally Posted by broken halo
HAHAHAHAHA, haven't thought about Johnny in a while!
Old Mar 6, 2020 | 07:57 AM
Palo "You", not your so called mechanic, disconnect both the positive and negative terminals from the battery.
Touch the positive and negative wires together. Hold them for about 30 seconds.
Reattach the positive and negative to the corresponding battery posts.
See if that works!
