Odometer and trip odometer stops
Old Mar 6, 2020 | 01:06 PM
big.paolo's Avatar
Originally Posted by TAINTER
Palo "You", not your so called mechanic, disconnect both the positive and negative terminals from the battery.
Touch the positive and negative wires together. Hold them for about 30 seconds.
Reattach the positive and negative to the corresponding battery posts.
See if that works!
Hy
i have disconnect both the terminals from the battery and i have joined them togheter.
After i have reattach them but is always the same.
All the instruments are ok. Only the odometer and the trip odometer are stop.
Any other test, please?
Paolo
Old Mar 9, 2020 | 08:27 AM
Time to buy a new cluster
Old Mar 9, 2020 | 09:47 AM
big.paolo's Avatar
Hy
they told me that’s enought to update the software in control unit.
Old Mar 9, 2020 | 01:46 PM
big.paolo's Avatar
Do you think it’s right (the software update) or it’s only wasted money?
thanks
Old Mar 9, 2020 | 03:00 PM
Can you switch back and forth from odometer and trip? What is the current odometer reading?
Old Mar 10, 2020 | 02:36 AM
big.paolo's Avatar
yes, i can switch from odometer (196.161km) amd trip odometer (0.00 km)
Old Mar 10, 2020 | 07:33 PM
Old Mar 17, 2020 | 02:37 AM
big.paolo's Avatar
Any other help please?
Old May 26, 2020 | 01:12 PM
QuandAns42's Avatar
If it is only the odometer, you may be able to just replace the stepper motor. However, it could be a sign of a deeper problem and you really don't want to be working on an odometer yourself as you're bound to trip the tampering warnings. Problems with instrument clusters can be complex because there are so many things coming together in that unit. I've had good experiences with https://www.instrumentclusterstore.c...t_clusters.htm and I'd highly recommend talking to them. They know more than the dealerships about cluster issues as far as diagnosis and compatibility. If it can be fixed simply they'll know how to help you out, and if it needs to be replaced, they can clone your old one so you're above board if you decide to sell down the road.
WannaScoopaDis
May 19, 2021 12:39 PM
happythree
Jan 17, 2016 07:16 PM
blckh2
Jul 30, 2012 07:07 AM
nlhummer
May 19, 2012 11:08 PM
