Right side actuator?
Old Aug 1, 2020 | 12:13 AM
H32006's Avatar
Default Right side actuator?
Hi,
Appears that I might have a dying window actuator on the back right passenger side.
Able to put the window down, but it won't go up from that door.
The driver control can put it up and down no problem.
Do I need a new actuator or could it be the switch?
Thanks.
Old Aug 1, 2020 | 02:51 PM
LatvjuAvs's Avatar
Time to tear down back right passenger doors, clean connectors, also grease them! Silicon pray the grove where glass slides up/down. Your truck is old and needs constant maintenance in ALL places.
Old Aug 2, 2020 | 04:10 PM
H32006's Avatar
Any reco's for a good silicone spray?
Also, should I attempt to hit the connectors?
Thanks.
Old Aug 3, 2020 | 12:19 PM
Electrical connections.....
Old Aug 3, 2020 | 01:36 PM
LatvjuAvs's Avatar
Unplug ALL connectors, clear with given cleaner, brush with toothbrush or something similar, you can use these tooth brush pikes ones, to get into connector holes.
Use tiny screwdriver to remove any green residue that does not come off with cleaner/toothbrush.
After cleaning connectors, I spray it with some sort of oily based stuff to preserve connectors against further water damage.
Fluid film, Liqui-Moly Electronic Clean/Protect Spray, silicon grease.
Also unplug connectors between doors and body, they also need servicing, small chance of breaking it all to high hell if there is big enough oxidation damage.
For silicone spray, I guess anything that contains silicone is good enough, and if sprays. I would love to try out "DuPont Teflon Silicone Lubricant" someday.
JimDrew
Jun 8, 2024 03:23 AM
humminchrome
Aug 14, 2022 01:03 AM
apollo18
Aug 25, 2020 01:11 PM
hummer_on_fumes
Nov 10, 2018 12:37 PM
MidTNHummer
Jun 12, 2015 08:35 PM
