Replaced thermostat today what fun...
Old Nov 20, 2019 | 05:41 PM
  #21
Originally Posted by Eurynomestolas
it wasn’t that dark. When I changed the thermostat I put a lot of it back in through a strainer. Plus I tested the coolant with a tester and it said it was good. I will do another test to be sure.
What type of tester? Coolant test strips? Refractometer?
Old Nov 21, 2019 | 01:27 PM
  #22
Antifreeze is cheap,and IMPORTANT. You did all the work to change the T Stat, please put in brand new 50/50 antifreeze. I us the pre-mix stuff, nobody can mess that up, not even me. At $17 per gallon, buy two. Saving $34 bucks now will look pretty dumb as soon as you have a cooling issue that will cost substantially more. No brainer.
Old Nov 21, 2019 | 01:50 PM
  #23
ski.dive's Avatar
here is where the temp is sitting
My TEMP. Gauge is also sitting in that same location= H3 runs perfect!!!
Old Nov 21, 2019 | 02:07 PM
  #24
Eurynomestolas's Avatar
ok doc I will change out the coolant
Old Nov 21, 2019 | 03:31 PM
  #25
I just want to be clear. I don't have any issue with that temp gauge, normal in my book for an H3 with a new T Stat.
I just think Eurynomestolas should replace the coolant with fresh. Might make a difference in gauge position, might not, but he/we will know he did it up right and not have to worry about coolant quality issues.
Old Nov 21, 2019 | 03:34 PM
  #26
Effective approach! All of my research must have fallen on deaf ears.
Old Nov 21, 2019 | 06:36 PM
  #27
MarkMc00's Avatar
No it didn't. It's not difficult to mix a gallon of concentrated coolant with a gallon of distilled water to get 2 gallons of 50/50 mix. AND, that's what the manufacturer recommends...I'm just say'in. But definitely do what makes you feel most comfortable.😊
Old Nov 21, 2019 | 07:11 PM
  #28
Not about how you buy it, it's about PROPER maintenance to extend the LIFE of the engine! No mixing with others, DC only!
Just like many think running temp in the "safe" or "normal" zone, is ok? All you need to do, is research the effects on engine temperature.
Since dexcool came out there have been many complaints, and from my research from the customer's, they did not mix/maintain it properly(now it's 50/50) Yes, today's dexcool is good for 150k miles, however it still needs changed every 5yrs.
So much information online these days, and you could also get a FREE coolant test at most shops these days.
I still have the OEM engine, and the temp gauge runs 1/2.
11preacher
Oct 12, 2019 04:35 AM
Hummerrican
Sep 2, 2015 08:28 AM
wifes h3
Aug 5, 2013 02:48 AM
rsc
Nov 16, 2012 03:08 PM
H3_4ME
Jul 9, 2012 03:02 PM
