coolant issue
Old Aug 4, 2013 | 04:47 PM
wifes h3's Avatar
Default coolant issue
So my wife's hummer is running a little under 3/4 mark. Took to a mechanic shop he tried radiator fan clutch and thermostat. I got it back and told him to put stock stuff back on because it didn't help. It had a cel which was coolant temp to low so I replaced coolant sensor. Its still running warm. What else is there to check. Thanks in advance
Old Aug 4, 2013 | 08:23 PM
Bunger's Avatar
Everyone's H3 reads a little different on that guage. Anywhere between 1/2 to 3/4 is normal.
Those gauges are not precision instruments. I wouldn't be concerned until the needle is in the RED.
If you really need to know if you are running over temp, then plug into the OBDII port with a scanner or reader to get the actual temperature while running. (something the mechanic should have done before just swapping in new parts)
Old Aug 4, 2013 | 09:12 PM
happythree's Avatar
I recently posted some fine detail on the gage and obd2 temps. the gage is pretty linear from a bottom of 90 f to a mid of 195. about 100 degrees for the low 1/2 of the gage area, pretty good accuracy and I can only assume it would continue above 195 on up to ?290 at the top! (another 100!)
I cant make mine go all the way to the mid point, just a notch below is 195.
I read 201 only when I turned the engine off and let it heat soak. I even had a blanket blocking the grill for a while. never 200 when running,never mid point.
Old Aug 5, 2013 | 02:48 AM
wifes h3's Avatar
He said the temp was at 229. I recently changed radiator 3 years ago do to leaking so I knew that couldn't be it. My thinking is with the code reading to low, the car was over fuelling making it hot. Guess I need to re check actual temp again. Do these cats clog up with out throwing o2 sensor codes?
Herm
Feb 5, 2008 09:16 AM
Herm
Jan 24, 2008 07:04 AM
syphon
Jan 2, 2008 01:26 PM
sgt940
May 23, 2007 08:46 AM
GregDiesel
Jan 6, 2006 03:24 PM
