engine temp
Old Sep 17, 2019 | 02:33 PM
11preacher's Avatar
Default engine temp
I have a 2006 H3 I just bought and replaced the leaking radiator, temp gauge is between 1/2 and 3/4 and OBII says 213F while running with ac on after driving over an hour, is that a normal temp or to high?
Old Sep 17, 2019 | 04:23 PM
Incorrect coolant mix is a common issue.
Old Sep 17, 2019 | 04:53 PM
11preacher's Avatar
flushed the system 3 times before radiator swap and put in new 50/50 Dexcool, also put in new thermostat that I think is 187 or 189degree
Old Sep 17, 2019 | 05:50 PM
Replace the cts ,stant 74192 oe replacement is only 10bucks with shipping.
Old Sep 17, 2019 | 06:01 PM
11preacher's Avatar
I'll try that thanks
Old Sep 17, 2019 | 06:14 PM
Great place to start since you had to flush the system 3 times? Or you could find a way to install a thermometer into your coolant system.
Old Sep 17, 2019 | 06:31 PM
11preacher's Avatar
I flushed the system cause the last guy topped off with green anti-freeze and wanted to make it was all out
Old Sep 17, 2019 | 08:14 PM
Whatever, my temp doesn't run to 213°F!
I recently checked the accuracy of the gauge.
Posted below, take note of my engine temp at startup was already @ 115°F(93°F ambient temp):
I just performed my annual temp gauge check, @ idle in my back yard, enclosed with 6ft wood fence:
Outside Temp: 93°F
KOEO: coolant temp: 113°F
Startup: coolant temp: 115°F
1/4 gauge: coolant temp: 154°F
Thermostat open: 194°F (drop to 190°F)
Center 1/2 gauge indicator: 195°F
Idle for 1/2hr: 199°F
AC on for 15minutes: 201°F
Indicator still points @ halfway mark, just to the upper part( scanner ect is the bottom line @201°F):
Old Sep 18, 2019 | 10:28 AM
Answer these simple questions. Where are you located and what was the outside air temp when you drove for an hour and saw 213F?
213F with the AC on is COMPLETELY NORMAL when it is hot & muggy enough outside to need to run the AC.
Do us all a favor, search "overheat protection" here or google: "H3 Hummer 3 levels of overheat protection".
Old Sep 18, 2019 | 10:47 AM
Yeah.... and your H3 is not his H3, is it?
It depends on many things, one of the most common reasons for an H3 running warm is a dirty radiator because somebody (current or former owner) just had to go mud bogging through big azzed dirty puddles.
Simple solution is to clean the radiator with a gentle spray of water. Might even use some mild soapy water on both front and back with thorough rinse.
