Replaced factory Monsoon Sub-woofer!
Old Jan 21, 2013 | 02:18 PM
R-code17815's Avatar
Default Replaced factory Monsoon Sub-woofer!
Here's the rundown...
The factory Sub & rear speakers were pretty beat when I got my H3 so I finally swapped out the factory turd.
This is the Sub I used, & I highly recommend it, ROCKFORD FOSGATE P3SD2-8 PUNCH 8" SHALLOW SUBWOOFER 2 OHM
It's an 8" shallow sub made for small enclosures.
150w rms 300w peak, Dual 2ohm voice coils (just like factory)
Being dual 2ohm make it a snap to hook to factory wiring.
Literally, all I had to do was cut factory wires off @ sub terminals, Strip the factory wire about 1/4" and stuff them into the Rockford's Push lock terms.
DONE!!!
It actually took longer to remove the interior panels then swap the speaker.
Shipped to my door, the sub was under $100.
Hits harder, Hits lower, no noise or distortion. Factory was starting to make some funky noises.
Few tips....
So you can get it all done the first time, lol.
Today was Rattle/Squeek fix day. I was In a hurry when I stuffed the Sub in so, now I got to do it correctly, lol.
1. Tighten all screws holding box together, 2-piece unit
2. Tighten Bolts holding Box to Chassis
3. Remove Factory Amp, cut a chunk of auto carpet in a square to insulate between box & amp, Retighten.
4. Stuff as much poly-fill in the area behind the amp as possible, make it tight. ( I had a rattle/resonance in the plastic box itself I could not get rid of any other way) Positive side note: Sub hits lower & harder!!!
Sounds better & I have no rattles!!!!!!
This Sub was a direct fit!!!! No Mods!!!! Just cut & strip factory wires.
As far as headunit I just swapped in an Alpine, My 3 didnt have the fancy Nav deck.
I'd give this a try before spending $500+ on a JL box, you might be surprised.
Old Jan 21, 2013 | 04:13 PM
qui's Avatar
qui
If I don't have the monsoon system, can I buy the components to install the sub/amp?
Old Jan 22, 2013 | 12:16 AM
jtceme's Avatar
Did you wire voice coils in parallel or series? Never pulled my sub before, always wanted to put in a stealth box, but too much $$.
Old Jan 22, 2013 | 07:17 AM
Factory Sub is dual 2ohm voice coil
Factory Amp has a separate channel for each coil.
Hooked up EXACTALLY like stock.
Old Jan 23, 2013 | 08:52 AM
mvrocky's Avatar
Where did you order the SUBWOOFER from ?
Old Jan 24, 2013 | 07:44 AM
E-bay
Old Jan 24, 2013 | 04:31 PM
Hummin0814's Avatar
Did you add an aftermarket amp? or replace / mod the factory amp in any way
Old Jan 25, 2013 | 07:12 AM
Nope, Factory Amp, No Mods!
Snip & Strip 4 wires from original Sub, hook up the exact same way to new sub.
Old Jan 27, 2013 | 09:38 AM
bowtiguy's Avatar
nice bang for the buck mod... mine rattles like no other.
I'll be ordering one of these 8's up today.
Old Jan 28, 2013 | 07:40 AM
Go heavy on the poly-fil, I've been messing with mine since install. I even carpeted the back of the sub-box to get rid of rattles & resonance from the plastic.
Night & day difference from the factory "Box O' Noise" I had, lol.
