Removing interior rear trim help!
Old Feb 4, 2020 | 01:32 PM
  #21
dwaddsy1's Avatar
Originally Posted by Eurynomestolas
All by hand carefully except that T-50 seat belt anchor
what is a "T-50 seat belt anchor?" I'm assuming that is the mechanism (the heart of the problem).
Old Feb 4, 2020 | 01:33 PM
  #22
dwaddsy1's Avatar
So I pulled the crap out of it. my entire body weight, quick snap and slow heavy as well as tried to real back as much slack in it. Tried slow and easy as well. No luck. There isn't much slack to start with so can't reallly truly push much back in..
Old Feb 4, 2020 | 01:45 PM
  #23
T = Torx head; 50 = size of Torx head.
Old Feb 4, 2020 | 02:42 PM
  #24
Broken Halo's Avatar
Start shopping for a new retractor. Also buy a new Torx mounting bolt....once removed you're supposed to replace. The old one will work, but it's recommended to install a new one. Don't just buy something that 'fits', get the proper bolt. Read the URL below. G.L.!
https://www.safetyrestore.com/hummer...-accident.html
Old Feb 7, 2020 | 03:19 PM
  #25
650Hawk's Avatar
I found that a set of panel tools is invaluable for removing interior (and even some exterior) panels/parts.
Like this Like this
Old Feb 10, 2020 | 02:39 PM
  #26
dwaddsy1's Avatar
Hello Everyone!
I wanted to thank you all for your contributions and advice. I used all of your help and successfully pulled off the trim (thanks Hummerz) and used a panel pulling tool I got that worked well (broke two plugs though) and then ordered a new seatbelt which I will be able to easily install when I get it. Thank you!!!!!
Old Oct 14, 2020 | 05:45 PM
  #27
Bailey2018's Avatar
Default Bang in rear of 2010
I bought a 2010 Luxury with Adventure package. I hear a bang in the rear when I hit a big bump or pothole. I have a spare tire with a hard plastic cover, that has a chrome band holding it on. I tightened the jack and checked to see if spare tire is tight. I jumped up and down on the back, but it didn’t make the bang. Any ideas?
Old Oct 14, 2020 | 06:13 PM
  #28
Easy to find, doing an elimination process, start by removing spare, then recheck for noise over bumps.
Old Oct 14, 2020 | 07:27 PM
  #29
Bailey2018's Avatar
Default Rear Bang
Ok, thanks
Old Oct 16, 2020 | 07:12 AM
  #30
Bailey,
Please start a new thread when you have a question unrelated to the post.
You should check the jack access area, storage cubby and any other items the previous owner might have stashed in the rear door jack access (ex. jumper cables).
hyperlight12
Apr 29, 2017 11:00 PM
ElliotF
Aug 21, 2014 10:48 AM
dowork
Jul 23, 2013 03:46 PM
47X
Nov 19, 2010 07:20 PM
vinceau911
Mar 29, 2008 08:51 AM
