Removal of center console (H3) for USB and A/V jack
Old Nov 18, 2019 | 09:17 PM
esfop319's Avatar
Default Removal of center console (H3) for USB and A/V jack
I am sure this has been done but I can't figure it out. I am looking to put a USB and A/V jack inside of the center console box and run the wire to my radio but I can't seem to be able to remove the console so that I can drill the hole in the console box for the mount and screw it in place from the backside and run the wire up to the radio. Any help would be appreciated.
Old Nov 19, 2019 | 11:38 AM
It is easiest with the front seats removed. 4 bolts and a couple wire connectors each seat.
Old Nov 19, 2019 | 05:16 PM
wpage's Avatar
May be better to route along the side under the door sill.
Then under the seat and up thru console.
Old Nov 20, 2019 | 07:42 AM
choochmalooch's Avatar
Cool
If you haven't used either of the blanks in the center dash panel you may want to put it there. There are two blank spots that can be easily made larger with a dremmel. Much easier to remove and work on.
Old Nov 20, 2019 | 08:32 AM
esfop319's Avatar
TY...Will look into that
Venomous
Feb 20, 2023 09:44 AM
Hummer2000
22
Jan 14, 2015 11:14 PM
Man1nboat
Aug 24, 2013 08:21 AM
2006 H2
Mar 16, 2009 11:33 AM
Bronx
Dec 18, 2008 08:49 PM
