refueling issue....
Old Mar 26, 2019 | 09:04 PM
  #41
NFS's Avatar
NFS
What mods have been done? A 12v system should never require over 15v charging. That alternator cant regulate.
intake, exhaust, kn filter, its tuned by super module
hid lights, hella horn. it runs fine no problem and very clean ride, it just this reduce power happened before and it went on its own and now its back again
and that fuel issue thing and that's it
Old Mar 26, 2019 | 09:23 PM
  #42
Start by pulling your "super module".
Old Mar 26, 2019 | 10:08 PM
  #43
NFS's Avatar
NFS
i can’t the ecm is tuned but Supermodulation. It’s a website that you send your ecm and they tune it and send it back
Old Mar 27, 2019 | 03:46 AM
  #44
Broken Halo's Avatar
[QUOTE=NFS;359198]
post the code[/QUOTE
when I researched online, some people say there is like a ball or something at the end of the filler line that have a ball or some sort to prevent that and it might be stuck or bad? some people say take it out...
is that true?
I'm not sure about our H3's but newer vehicles have a 'roll over' safety (check valve?) to keep fuel from spilling in a roll over accident. Possibly that check valve is stuck open and is not shutting off when tank is full? Just throwing out ideas here.
Old Mar 27, 2019 | 05:38 AM
  #45
NFS's Avatar
NFS
[QUOTE=Broken Halo;359221][QUOTE=NFS;359198]
I'm not sure about our H3's but newer vehicles have a 'roll over' safety (check valve?) to keep fuel from spilling in a roll over accident. Possibly that check valve is stuck open and is not shutting off when tank is full? Just throwing out ideas here.[/QUOTE
yes I am confused too. I am gonna push air with air compressor on the other hose that vent to the tank or run something into it maybe something there... I am willing to try everything. If this came clean and didn’t fix the problem then my only last Option is to change the filler neck.... unless someone else got another idea...
Old Apr 1, 2019 | 12:01 AM
  #46
GrampaEJ's Avatar
Be careful, which direction you blow compressed air. You may cause more problems than you have, now.
Too much pressure at a valve could break it, and block the passage it's trying to regulate, or leave it wide
open and not close off the passage when it's supposed to.
That being said, Hummerz is right on the mark. Your alternator is putting out too much voltage.
Just because it's new/rebuilt doesn't mean it can't be defective.
Trust me, 23 years in the automotive parts industry, at a reputable parts company, I know a thing or two.
Good luck.
Old Apr 7, 2019 | 10:52 AM
  #47
NFS's Avatar
NFS
When I unplug the vent hose from the tank . No issue , when I plug it back on then when I refuel it spits out. I tried compress air toward the tank and I can see air coming back so it’s not blocked so I am not sure
Old Apr 7, 2019 | 12:03 PM
  #48
How do you see air? Where did you blow the air? Note 10 & 11 is the vent:
Old Apr 7, 2019 | 12:12 PM
  #49
NFS's Avatar
NFS
I blew air in number 10 when you unplug that hose that connect to the tank, I blew air toward the tank from that hose and I can feel air coming back
Old Apr 7, 2019 | 12:17 PM
  #50
You disconnected the vent, so the problem is between 10 & 11. Did you disconnect 10 at all connections and blow air through it?
