refueling issue....
Old Mar 20, 2019 | 03:54 PM
NFS's Avatar
NFS
Default refueling issue....
Hello, I have a 2007 hummer h3 luxury package around 56000 miles on it. the problem Is when I fill gas and its full and the pump shut off automatically. it spells gas from where the bump id plugged. I checked the vent hose and its not clogged I took it off and did compress air in it and it was fine.. what the problem might be? please I need help I don't know what else to look at to fix this issue.
thank you
Old Mar 20, 2019 | 04:47 PM
Broken Halo's Avatar
[QUOTE=NFS;358947]"it spells gas from where the bump id plugged."/QUOTE]
WHAT??!!
Old Mar 20, 2019 | 05:08 PM
NFS's Avatar
NFS
[QUOTE=Broken Halo;358950]
WHAT??!!
i dont know how to explain it but it spit gas when it’s full and the pump shut
Old Mar 21, 2019 | 10:39 AM
wfturner's Avatar
You need to explain your problem in more detail
Old Mar 21, 2019 | 02:33 PM
Banshee32g's Avatar
Default i think i know what your saying
dont top the tank off. mine does the same. once its full stop. dont top off. there is a overfill slot that fuel will leak from.
Old Mar 21, 2019 | 08:09 PM
Not sure what you are writing? If you are having a problem fueling, you need to replace the vent valve.
Old Mar 24, 2019 | 12:32 PM
NFS's Avatar
NFS
I replaced the vent solenoid and it still does it.
I don't top it off, I just put the pump and pump the gas and when the pump shut off. it spits a good amount of fuel out....
this video show how mine does its the same
I ran out of ideas what else could be the problem, I checked the tube that attached to the filler neck, and its clear, I replaced the vent solenoid with brand new one with its hose and still does it ... please help
Old Mar 25, 2019 | 01:14 PM
Try a different gas station?
Old Mar 25, 2019 | 01:25 PM
NFS's Avatar
NFS
did you look at the video I provided above? Please watch it . I tried different gas stations and pumps and still same issue
Old Mar 25, 2019 | 02:36 PM
wfturner's Avatar
Have you tried what the HumbleMechanic suggested ?
Try filling with the gas nozzle at a lower fill speed and stop when near full
