refueling issue....
Old Mar 25, 2019 | 02:49 PM
NFS's Avatar
NFS
Originally Posted by wfturner
Have you tried what the HumbleMechanic suggested ?
Try filling with the gas nozzle at a lower fill speed and stop when near full
yes and it didn’t work, someone told me to try to get vapor canister so I ordered another one and once it arrive I am gonna install it and see if it will fix the problem... but what else might cause this?
Old Mar 25, 2019 | 05:54 PM
talusfan's Avatar
type a coherent sentence then people will try and help you.
[QUOTE=NFS;358947]"it spells gas from where the bump id plugged."/QUOTE]
Old Mar 25, 2019 | 06:18 PM
NFS's Avatar
NFS
[QUOTE=talusfan;359139] type a coherent sentence then people will to try and help you.
Old Mar 25, 2019 | 08:48 PM
[QUOTE=NFS;359141]
Originally Posted by talusfan
If you can't type a coherent sentence then don't expect people to waste time to try and help you.
It’s hard to explain, I am asking for help
Old Mar 25, 2019 | 08:54 PM
That could be a possibility if the canister is fuel fouled. You need to check the evap system again to make sure there are no obstructions.
Old Mar 25, 2019 | 09:26 PM
NFS's Avatar
NFS
New canister coming on the way , I will
recheck the vent line also, anything else you recommend to check?
Old Mar 25, 2019 | 09:28 PM
NFS's Avatar
NFS
That could be a possibility if the canister is fuel fouled. You need to check the evap system again to make sure there are no obstructions. https://www.youtube.com/watch?v=wa2KLfc894I
also one thing I forgot to mention is that I don’t have check engine light or codes but I hope the new canister will fix the problem, I will Let you know regardless once I get it and install it
Old Mar 25, 2019 | 10:19 PM
I can recommend 1 main thing, "NEVER TOP OFF" !!When the pump shuts off, STOP fueling or you can cause damage to the evap system and end up with issues. The vent valve(mounted on the canister) is the most common problem that I have found when this happens. Don't take my advice I only have 37yrs in auto repair.
Old Mar 25, 2019 | 10:29 PM
NFS's Avatar
NFS
thank you for the advice, I never top off but looks like the previous owner did. I bought the hummer recently and noticed this issue
Old Mar 26, 2019 | 02:35 PM
talusfan's Avatar
Wink
None of this is necessary.
