rattle from airbox while the hood is closed
Old Jul 17, 2020 | 03:28 PM
You didn't answer the question: Did you swap the coils? Try swapping #5 with #3 and see if the misfire cylinder changes on your scanner. Btw, most common for misfires on cylinders #1 & #5(front and rear), source due to, air to fuel ratio imbalance, especially if the misfire only occurs at low rpm's.
Old Jul 22, 2020 | 10:40 AM
Lord_Vien's Avatar
So you're gonna get a laugh out of this. I should have followed your advice this whole time on the wiring lol. Small hole in the green wire the grey outside wire that goes to the map sensor. Once i fixed that all issues were solved. Hey trial and error on my part i guess.
Old Jul 22, 2020 | 10:58 AM
Live and learn. Now you got a good used map sensor and a set of coils backup, if ever needed in the future.
Mcarter64
Jul 13, 2020 06:32 PM
user 956363738
Jan 3, 2020 07:20 PM
LooseMoose
Sep 2, 2010 07:15 PM
haiminger
Jan 15, 2008 09:14 AM
