quick question i tried searching first.
Old Mar 15, 2019 | 05:28 PM
Banshee32g's Avatar
Default quick question i tried searching first.
for some awful reason the search function is giving me hell ive tried quotes etc to no avail. so my 08 alpha does not have the adventure or offroad package or whatever its called. can i switch the tcase to the adventure models 4:1 without any issue? or do i have to modify other parts as well? as far as the lockers go im dropping in some detroit lockers as they are beasts and I get 60% off due to being a detroit certified technician and having access to certain things. also i found 2 dana 60s a buddy of mine has front and rear gm 60s with a pass drop on the front that i can get for 1k for both so at some point ill be doing a SAS once i get the money saved and dropping a 60 in the rear also. any insights? also does anyone have a part # for a complete 4:1 t case?
Old Mar 15, 2019 | 05:42 PM
Banshee32g's Avatar
for some awful reason the search function is giving me hell ive tried quotes etc to no avail. so my 08 alpha does not have the adventure or offroad package or whatever its called. can i switch the tcase to the adventure models 4:1 without any issue? or do i have to modify other parts as well? as far as the lockers go im dropping in some detroit lockers as they are beasts and I get 60% off due to being a detroit certified technician and having access to certain things. also i found 2 dana 60s a buddy of mine has front and rear gm 60s with a pass drop on the front that i can get for 1k for both so at some point ill be doing a SAS once i get the money saved and dropping a 60 in the rear also. any insights? also does anyone have a part # for a complete 4:1 t case? is it the nr3 nr4 or nr6 option?
Old Mar 15, 2019 | 05:45 PM
happythree's Avatar
to find car parts,google car-part.
connects to most usa junk yards.
Old Mar 15, 2019 | 09:21 PM
Banshee32g's Avatar
yea i use car-parts.com all the time. just got the dash bezel from an 09 that includes front and rear locker switches so ill hook those to my detroit lockers
Old Mar 16, 2019 | 06:50 AM
Ordieh's Avatar
NR6- BORG WARNER 4494- GM part # 24247594
Old Mar 16, 2019 | 07:39 AM
The T Case is a direct bolt in swap. There are two different Transfer Case Control Modules. From the factory all the Off Road/Adventure trucks have one version, and the rest have the other (I do not remember the part #s while typing), but you do not have to change the TCCM for it to work correctly.
I merged your separate identically name threads.
cdeverocks7
18
May 9, 2019 10:01 AM
telemike
Oct 9, 2012 10:21 PM
climbnh
Jan 9, 2012 07:06 PM
Bbal276
Jan 8, 2012 01:55 AM
Davidh3
Aug 4, 2011 07:40 AM
