Question about Tire and wheels
Old Nov 2, 2013 | 12:01 AM
  #41
Sounds like another 85-305. Didn't take anyones advise, knew everything and eventually was gone.
Yep, anyone who has wheeled with us knows how we like to "thrash" our rigs. Pretty much a point and mash the skinny pedal wheeler.
Not at all. Judicious use of the skinny pedal and proper lines can save many broken parts. I'm usually the first one to advise to back off the accelerator and try a different line. Although I do also believe that broken or damaged parts are sometimes part of tackling larger/harder obstacles. Once that happens, replace the part/parts with stronger better parts. I don't agree with the stronger half shafts argument. I prefer a "fuse" I can repair on the trail vs anything broken in my diff.
Still abide by the 315s on OEM rims will be just fine on your H3/H3T. Any idiot can break parts even with 265s on the paved road. Finesse is the key to longitivity of the IFS.
  #42
Xlr8n's Avatar
Originally Posted by davidducati
Tainter my points have yet to be shut down brother! If you are still trying to prove some point by saying its fine to run 35" or 37" tires on a bone stock h3 and just "crank" the t-bars, all your doing is proving how wrong you are. Without question you are puting added stress on the drivetrain. Unless you are insane you cannot argue that! Cast diffs, stronger cv joints, reinforcing the steering are all things that "should" be done to handle the added forces applied with larger tires. For guys who say "don't worry just stick 35" under it and go" you boys sure know a lot about the Warranty dept. and what they will allow. As a Tech myself I know a little about the warranty process. But around we go and I will say it one more time, have fun abusing your rigs and keep taking them into the "good ol' boy" deals to get fixed. I will continue to wheel without trashing my truck because I built it for the trail. I hope you new Hummer owners use your heads and make wise choices when it comes to just pitching bigger tire on just because they don't touch the fenders.
What part of this don't you understand?: People have been running H3's with 35's and a torsion crank for going on 8-9 years now. Some have over 100k miles on them. Your warning doesn't hold water aside from the fact that folks can actually bust stuff running bone stock factory 265/285's if they don't know how to wheel an IFS rig. But we already know that, so your warning on how to properly set up an H3 is nothing that hasn't been discussed for years here.
If you'd do a little reading here you'd see that most guys that seriously wheel their rigs do reinforce the steering rack, even if they are running 285's. None of the stuff you are bringing up is groundbreaking. It's been discussed here a million times.
Old Nov 2, 2013 | 09:26 PM
  #43
davidducati's Avatar
If you go back to the first post, one of you "senior" members ask the question
"Can I go back and put OEM tires back on my 22" wheels to get more sidewall"??????
Sooooo...... Ya, you can hop in a cold bath and yell out how hot it is all ya want, does not make it right. You do realize you are arguing that it is not a good idea to beef up your rig when going from a 31-33" tire to a 35-37" tire on a ifs truck. I was trying to help a misguided fellow hummer owner and you are calling me wrong? Your fools! Period.
Old Nov 2, 2013 | 11:11 PM
  #44
DD no one is saying not to beef up your truck if you want to, they are telling you that you don't have to, especially if you know how to wheel your truck.
Old Nov 4, 2013 | 12:41 AM
  #45
#1. HUMMER NEVER produced a vehicle with a 31" tire. The OEM Goodyear Wrangler RT-S 265/75R16 was a 31.8" tire. What almost everyone in the tire business considers a 32" tire.
#2. No one is agruing that modification is wrong. We are still trying to get you to admit that your post below is just not true on both accounts. YOU CAN RUN UP TO A 35" TIRE WITHOUT ANY MODIFICATIONS & YOU DON'T NEED A LEVELING KIT TO RAISE THE FRONT END.
Twisting it into something else will not make what you posted below correct in any way at any time.
without a lift you will struggle to get any more tire as right now you are running what equates to a 33" tire on an h3. With a leveling kit you can run up to a 35" tire.
Old Nov 4, 2013 | 08:09 PM
  #46
Keep stretching for that last 1/2" there Tainter! For the first time I somewhat agree with you. You "can" put a 35" tire on an un modified h3, not arguing that. It's if it recommendable to tell a newby to. Putting lipstick on a pig does not make it a women!
Old Nov 5, 2013 | 09:44 PM
  #47
RaYoSeKiZ's Avatar
it's over....
Please locked this thread!!!
Old Nov 5, 2013 | 10:55 PM
  #48
happythree's Avatar
yeah, that's the first one who will just not join in, got his own agenda.
Old Nov 10, 2013 | 03:36 AM
  #49
amrg's Avatar
I've put 35" tires on my 3 without even leveling it. The only 2 issues I had were:
1. Rubbing on the sway bar at full lock
2. Rubbing on the OEM fender flares that I have installed.
Issue solved by cranking up the truck.
Being running 35's on two different trucks at the same time, unlike the other guys, I didnt beef up my steering or change my CM bushing (although I must because its due). Been 2 years on both trucks, 35K miles on one and 20K miles on the other, not a single related issue.
Old Nov 10, 2013 | 03:37 PM
  #50
rsc's Avatar
rsc
No-one is going to argue that 35's don't put additional stress on the suspension. We're just saying that the truck can take it. And there's nothing rednecked about it. Just because I didn't over-pay for a lift? We've fought hard to avoid the "Hummer Tax" from the aftermarket. Having owned some European cycles in the past I'm very familiar with the snobbery that if it isnt carbon fiber or unobtanium and obscenely expensive, then its a POS. I don't buy it.
