Question about Tire and wheels
Old Oct 21, 2013 | 09:41 PM
RaYoSeKiZ's Avatar
Default Question about Tire and wheels
Hi guys I apologized for this question that might sound pretty newbie to you but to be honest I am as far as this stuff is concerned.
My 08 H3 is currently on a 305 45 22 Tires, now I plan to get more rubber and get the OEM 265 65 18...
Can I just purchase an OEM tires and keep the wheels on it???
Thanks a lot for your input.
Old Oct 21, 2013 | 11:52 PM
egroegart's Avatar
You can't put a 265 65 18 tire on a 22 inch wheel. You can only put that on an 18 inch wheel.
Old Oct 22, 2013 | 12:43 AM
New York City's Avatar
Last number of the tires will always be the rim size.
In your case as stated; 18 is for 18 inch rims only.
Old Oct 22, 2013 | 06:08 AM
Bunger's Avatar
A 265/65/18 tire will be SMALLER diameter by about 1.3" than the 305/45/22 tires you have now.
You have about a 33" tire now.
Are you trying to keep your 22" rims?
How big of a tire diameter do you want to go to?
Once you tell us that, then we can suggest a tire size for you.
Old Oct 23, 2013 | 11:40 AM
RaYoSeKiZ's Avatar
Thanks for your reply. Yes i want to keep my wheels but I also want to get more rubber this this time than that of my previous low profile tire. Which tire would work??? Thanks
Old Oct 25, 2013 | 12:08 PM
RaYoSeKiZ's Avatar
Any help taken from here will be much appreciated
Old Oct 25, 2013 | 01:19 PM
davidducati's Avatar
without a lift you will struggle to get any more tire as right now you are running what equates to a 33" tire on an h3. With a leveling kit you can run up to a 35" tire.
Old Oct 25, 2013 | 01:27 PM
Bunger's Avatar
False on both counts.
You can get a 35" tire on an stock H3 with no problem, even without "leveling".
And you don't need a "leveling kit". You can just adjust the torsion bars to level an H3, no extra hardware needed.
Old Oct 25, 2013 | 01:54 PM
stubbsy's Avatar
Dude the best I can find is a 305/50R/22 from Toyo they say it's an all terrain tyre and it's 34" tall.
Old Oct 25, 2013 | 02:53 PM
RaYoSeKiZ's Avatar
I have a torsion bar adjusted and my H3 was leveled nicely.
All I need to know is using my current 22" Rim I wanted to shift from low profile tire to a more rubber ones...so which TIRE can you recommend.
Thanks so much to all who responds....
