pulsing lights
Old Jan 17, 2022 | 11:36 AM
Originally Posted by daniel5455
i am using stock terminals but they are clean. I also check the HL switch and no difference. Also If the engine is not running the lights don't pulse.
You are missing the point. Stock OEM Battery Terminal Connectors are for chit, bad, suck, defective.................. get it yet? It is not a matter of "if" they fail, they all will because they are junk. I do not care how much cleaning you have done to the old crappy azzes battery terminal connectors, they need to go, ASAP!
Do some searches on the H3/H3T Battery Terminal Connectors. Poor connections to the battery cause significant issues in computer controlled vehicles and the H3/H3Ts are known to Gremlins caused by the factory connectors. Just like your problems.
Old Jan 17, 2022 | 02:26 PM
daniel5455's Avatar
what do you think of this SHT301 I like the idea of the volt meter on it.
Old Jan 17, 2022 | 02:49 PM
daniel5455's Avatar
Also can you recommend any terminals from Amazon or Autozone or similar stores? I cant find any stinger terminals local and want to see if this resolves the issue.
Old Jan 17, 2022 | 03:32 PM
You have to open the hood to check volts. Too much work for me, I use a simple plug and play.
Old Jan 17, 2022 | 03:48 PM
I got mine on ebay 10yrs ago for under $20pair. Still a great price here:>>> Two Stinger Battery Terminals SPT53501 Multiple Output 4/8 AWG Positive/Negative
Old Jan 17, 2022 | 04:09 PM
I also remove alarm system cpu to see but no different.
??? What's the voltage inside the cabin? Check auxiliary outlet with a meter or a plug in like I posted above.
Old Jan 17, 2022 | 04:10 PM
daniel5455's Avatar
thanks i just ordered those. If its not the terminals what else should i check?
Old Jan 17, 2022 | 04:13 PM
Old Jan 17, 2022 | 04:18 PM
daniel5455's Avatar
after car sitting in freezing cold for about 7 hours 12.6V when i start engine its at 14.7V
Old Jan 17, 2022 | 04:21 PM
Tested inside the cabin or at the battery?
