Problem with starter/immobilizer
Old Sep 24, 2024 | 11:32 AM
Tancredix68's Avatar
Default Problem with starter/immobilizer
Hello guys, I need a help, please.
Ignition goes on, brake light was broken, so we bridged it. Lights on dashboard go in but the starter does nothing, not even a click. Immobilizer light on Dashboard is sometimes on and after starting attempts it goes off. Battery power is available enough
Old Sep 24, 2024 | 01:06 PM
Welcome. What is the voltage of your Battery at rest?
If your brakes had a short, as in the common wiring rubbing the chases above the license plate which you can see between the bumper with the back swing gate open, then your battery may be too week and still shorting.
Year and Miles is always important.
Otherwise look up GM PassLock.
Old Sep 25, 2024 | 03:06 AM
Hello, thank you very much for now. I am trying to solve this problem. I let you know . Regards
Old Sep 26, 2024 | 02:18 AM
Happy Hummer's Avatar
Let's start at the beginning.
Have you recently done any work or add ons?
1. Battery Internal damage
2. Ground strap too block/frame
3. Power wire to starter
4. Fuses
5. Fuse box failure
6. Starter shorted
7. Passlock failure
Old Sep 27, 2024 | 02:12 PM
650Hawk's Avatar
Originally Posted by Tancredix68
...brake light was broken, so we bridged it...
I have no idea what this means.
MichiganHummer
Oct 1, 2023 06:30 PM
edwin2010
Apr 9, 2018 10:47 AM
CARdiac
Oct 18, 2015 02:11 AM
BiG_Ze
Aug 10, 2012 09:03 AM
SSP Boss
Apr 29, 2011 10:04 PM
