Power window switch illumination on H3
Old Jan 25, 2024 | 04:00 PM
teahead's Avatar
Default Power window switch illumination on H3
Is it true that after 2007, the passenger and rear switches do not light up by the factory?
That's the case w/my 2009.
Old Jan 29, 2024 | 09:17 AM
650Hawk's Avatar
On my 2008, both the driver and passenger side lights up; not 100% sure about the rears.
Old Jan 29, 2024 | 09:46 AM
Golden Hurricane's Avatar
Wouldn't the factory manual tell you... generally, when the factory is describing a feature...the factory will mention "illuminated"...or something similar.
Old Jan 29, 2024 | 03:05 PM
2010 H3T Alpha - Rear switches are not illuminated.
Old Jan 29, 2024 | 05:22 PM
teahead's Avatar
OH wait, now I notice, the passenger side DOES work, but not the rears.
I found this thread:
https://hummer4x4offroad.com/forum/t...witches.12311/
Old Jan 29, 2024 | 06:17 PM
Same rear switches on ALL H3's. Btw, when is there a need for illumination on rear door switches?
Old Jan 30, 2024 | 05:32 PM
Justinh's Avatar
Lemme guess ... when it's dark? The same reason any switches would need to be illuminated
Old Jan 30, 2024 | 08:33 PM
Those switches are disabled with a press on the master switch.
Old Jan 30, 2024 | 08:47 PM
Old Jan 31, 2024 | 10:56 AM
Happy Hummer's Avatar
No! The passenger side and drivers and two rear light up on a 2007 Hummer h3.
the bulbs are non obtainium though.
You'll need to solder in a bulb to work, because GM in there infinite idiocy (MHO) chose different bulb types which are now discontinued haha.
