P0017 & p0014
Old Sep 26, 2020 | 06:51 PM
How is it dangerous? been my go to test for many decades, also works great when I have to pull a towed in parking lot drop, fuel pump failure, into the shop, to repair. You can also try starting fluid, which may cause damage to the engine, or throttle body cleaner works too. If it starts, then you have a fuel issue, if not, you know there's another problem.
Btw, as state above you can take a prybar on the CK pulley and see if moves.
Old Nov 25, 2020 | 08:08 PM
gwarrend's Avatar
Update... Root of my problem was that the timing belt tensioner broke. The oil on top of the valve cover was a small crack (now fixed). A bag of money later and my engine has been rebuilt. Runs great...
Problem - I still have the infamous stalling when the truck is warmed up and coming to a stop. It does not happen in the first 10 mins when truck is cold. After than, RPMs bounce around and it periodically stalls unless I hold the RPMs wit hthe gas pedal while slowing down to a stop.
Any ideas? Ive read a lot here and online re this stalling issue. Ive removed and cleaned TB 2X, MAF 2X, tried changing the EGR valve. What next? Thinking O2 sensors, MAP sensor, fuel filter/pump.... Also booked an appt w dealer to update PCM (fingers crossed).
Thanks.
Old Nov 29, 2020 | 12:09 AM
gwarrend's Avatar
I changed my Camshaft Position Sensor to a generic amazon one. Today I bought an AC Delco and now the truck seems to idle better but still stalls when the truck is warmed up and harder braking/stopping.
PCM flash Tueday.
Old Nov 30, 2020 | 10:53 AM
H3s do NOT have any EGR valve. Did you check that all the fasteners for the intake manifold are tight?
This is the list: Acts like it wants to stall/rough idle -No CEL -What To Do:
Old Nov 30, 2020 | 11:14 AM
gwarrend's Avatar
Thanks Doc. I have checked and the manifold is tight.
Yesterday, I did a number of hard stops to simulate and diagnose. One time the Word OIL flashed on the dash so I pulled over and checked .... the oil was at the bottom of dipstick. Odd since engine was rebuilt 1200 kms ago. I topped up the oil and has not stalled since. Guess H#s have an auto shutoff for where the oil gets too low. Will continue to monitor. Fingers crossed I don't have a leak somewhere.
Old Mar 31, 2026 | 08:12 PM
magamaga's Avatar
Was this resolved . I am having the same symptoms and I am now afraid that if I replace the timing chain and tensioners, it might be something else. The truck is throwing errors p0016, p0017, p0365 and p0366.
Help!
Old Mar 31, 2026 | 08:13 PM
magamaga's Avatar
Help!
One more thing. When the truck is at idle , the oil light comes on and if I accelerate, the light goes out. The stalling only happens sometimes when starting the truck.
Old Apr 1, 2026 | 09:44 AM
Help!
Welcome to HF. Please START A NEW THREAD.
We do not need to resurrect this SIX YEAR OLD Dog. READ: Old Threads/'Necro-Bumping'
jvorpahl
Jun 8, 2019 08:27 PM
AyGuey
Jun 18, 2018 11:30 AM
user 956363738
Mar 6, 2017 11:38 AM
Palmerth
Apr 29, 2016 06:30 PM
marine6132
Feb 15, 2014 07:37 AM
