One Headlight Dim
Old Jul 20, 2023 | 08:13 PM
Kevin10Skidoo's Avatar
Time to check continuity and voltage drop for each of the headlight wires. Individually lol. Back probe each wire at the light socket (the back of the light housing) and then connect the other end of the probe at the fuse or the Relay respectively. I'm guessing you got the green crustie growing.
found out I had the ground and the low beam wire flipped since March.
The new wire had a black on the edge. So I assumed Ground. Turns out ground is the middle. I have it hooked up correctly now.
Do I need to take a battery terminal off or let it reset somehow? I assume there is a protection mode?
Old Jul 20, 2023 | 08:30 PM
brothapig's Avatar
If you still have your extra ground installed, you need to remove it. This system needs to work with a floating ground on the circuit not being used (low beam or high beam). Take a look again at the schematic, specifically on the relay I mentioned (relay 70).
cooter
Jun 9, 2022 07:34 AM
ski.dive
Feb 18, 2019 08:51 AM
Enemy
Apr 9, 2009 05:46 PM
hotrod
Feb 5, 2009 08:08 AM
surftrish
21
Jan 3, 2007 01:07 AM
