Oil/water in the Air Intake System (Brownish Foam)
Old Feb 26, 2011 | 11:43 PM
drtom's Avatar
Banned
Default The book sez
short quote,,,if abnormal operating conditions arise the system lets excessive blowby gases back into the air resonator to be burned in normal combustion..... so you get to guess what causes the abnormal blowby gases. the pcv "pipe is a .1 in orfice lets crankcase gases into the intake,not the resonator,prob baffled as mentioned,so the gases/oil gets into the resonator by going backwards thru the long hose. obviously if it continues,its somthing "abnormal",not fun.
Old Mar 10, 2011 | 06:14 PM
Learjet405's Avatar
Speaking of cleaning the throttle body, has anyone heard that you can mess up the Throttle valve by opening it up manually to spay cleaner inside. Mine idles rough after cleaning and is giving a very intermittent cylinder #4 Misfire code. I am being told I might have messed up the throttle body by doing this. Never had a problem on any other truck but looks like this one is motor controlled instead of spring operated.
Old Mar 11, 2011 | 12:20 PM
largemouthbass's Avatar
These are all 06 models... I'm going with head issue
Old Mar 11, 2011 | 05:17 PM
NJTEX's Avatar
As soon as I get a weekend in the 50's again, I'll do a compression test and post the results.
Old Mar 11, 2011 | 05:45 PM
dan perez's Avatar
For what its worth.., Something similar happened to my '93 Caprice. It turned out to be a bad radiator cap not allowing the enging to get up to proper operating temperature.
Old Mar 11, 2011 | 07:12 PM
Widespread Hummer's Avatar
Did that "someone" explain if the throttle body is now messed up why it would only throw a code in the #4 cylinder? Or how it could "mess it up?" That logic seems suspect.
If this happened only after you cleaned the throttle body have you checked your reassembly? Did you do something to that coil pack during reassembly? Or as stated already, head issue.
Old Mar 11, 2019 | 04:18 PM
hummer_on_fumes's Avatar
You just replied to an 8 year old thread and someone who's account's last activity was 02-28-2011
Cue Doc blowing a gasket (in his head not Hummer)
Old Mar 11, 2019 | 08:57 PM
GrampaEJ's Avatar
Way to go hummer_on_fumes. You beat Doc to the punch.
Old Mar 12, 2019 | 06:44 AM
choochmalooch's Avatar
Cool
NEWBS, what are you gonna do?
Old Mar 12, 2019 | 09:09 AM
Oh boy....
Ewmoore99
Sep 5, 2018 10:19 AM
Aaajaws
Feb 15, 2018 08:39 AM
Justinh
Sep 9, 2017 02:41 PM
hakan
Feb 9, 2017 10:33 PM
importkiller
Nov 11, 2006 03:07 AM
