oil pressure light and alarm comes on at idle.
Old Dec 13, 2024 | 07:53 AM
treetom's Avatar
Default oil pressure light and alarm comes on at idle.
Hummer 3
oil pressure alarm and light come on at idle.does not seen to be idling low and has no low oil pressure sounds
Old Dec 13, 2024 | 02:18 PM
Welcome treetom, MOVED this for you to the H3 section. The New Member section states it is strictly for intros.
YEAR and Miles is always important to tech questions. There are other threads here on this topic, please search them out but do not tack on a question to dig up an Old Thread, read them.
What oil and oil filter are you using? Have you checked the oil for level and quality? Any recent work done before this started?
A common possible cause may be a bad oil pressure sensor or its wire connection and harness.
Old Dec 29, 2024 | 02:40 PM
wpage's Avatar
Originally Posted by treetom
Hummer 3
Welcome...
Hard to say without some data like year model miles etc...
Like said could be a bad sensor.
Old Dec 31, 2024 | 11:08 PM
brothapig's Avatar
Certainly check the oil system thoroughly. After that, though, I would focus on the sensor. Located above the oil filter and accessible through the wheel well with the inner fender off.
I have replaced mine twice, both times the same symptoms you are describing.
I had a thread with some pictures of the tools needed. It is not a hard job with the right tools.
Check for oil leaking into the electrical connector.
JWoody
May 17, 2024 10:17 AM
steamboatrock
Feb 25, 2023 11:19 AM
2005H2
Jul 7, 2021 01:08 PM
RJ3607
Sep 4, 2015 08:29 AM
man-of-war
26
Aug 23, 2015 09:23 AM
