No Crank No Start No Communications Port After Sitting???
Old Oct 15, 2023 | 10:29 AM
Cryptoyeets's Avatar
Default No Crank No Start No Communications Port After Sitting???
Hi everyone, after lurking a little while, I finally had to make an account and ask for some advice. I'm trying to get this '08 Hummer H3 3.7l back on the road after 4 years of sitting. I checked all wiring harnesses & changed the oil, threw in some fuel stabilizer/Heet, and put in a new battery. It originally cranked but would never start so I assumed it's probably bad gas as it's been sitting for 4 years.I disconnected the battery for a week, and then I siphoned all the gas out by going under the truck and pulling the fuel filler hose from the tank. I put 5 new gallons in the tank, and then reconnected the battery. When I put the key in, the fuel pump doesn't engage, and it does the door chime 4 times, and then repeats every couple of minutes. Everything lights up, and works. I tried connecting my code reader and it keeps showing no connection. I was thinking it could be a fuel pump, but I'm not sure as it was working last week & my code reader will no longer work so I feel it might be electrical. Any help is needed! Thank you
Old Oct 15, 2023 | 01:29 PM
Happy Hummer's Avatar
So, last week you could communicate with pcm through datalink?
we're there dtc's at that time?
was the vehicle kranking?
Old Oct 15, 2023 | 01:33 PM
I'd start at the fuse box and verify with a test to each fuse (one at a time lol) visually and with dvm that they are known good.
I'd verify each relay was good.
I'd make d@mn sure that main circuitry was good.
You can connect a remote switch to starter to test if it indeed turns engine over. In park lol.
Old Oct 15, 2023 | 01:34 PM
You can jumper relay/fuse for fuel pump to test if it will activate.
Old Oct 15, 2023 | 07:42 PM
hopefully critters have not chewed your harness wires. also check your body ground points for corrosion. especially if it was sitting on dirt or moist shaded area for the 4 years.
Old Oct 16, 2023 | 09:14 AM
Is the "new battery" fully charged?
Are you still trying to use the Crappy Azzed OEM Battery Terminal Connectors? If so, hack them off and replace with a quality aftermarket set like Stingers or your favorite brand.
Peter James Belmont
Mar 2, 2016 01:49 PM
Captchee
Dec 21, 2013 08:39 PM
z_pad_69
Apr 18, 2013 02:53 PM
tuffenuff
Jul 13, 2012 06:03 PM
MURDERDOUT
May 3, 2009 10:54 PM
