No beep when locking doors
Remote Keyless Entry (RKE) Feedback (RFA) settings on the Hummer H3 allow you to customize how the vehicle responds (horn/lights) when locking or unlocking with the key fob. These settings are accessed through the Driver Information Center (DIC).
RFA Settings Modes:
RFA Settings Modes:
- Mode 1: Park lamps flash on lock/unlock.
- Mode 2: Park lamps flash and horn chirps when locked; only park lamps flash when unlocked.
- Mode 3: Park lamps flash and horn chirps on lock and unlock.
- Mode 4: RFA is inactive (no lights or horn).
- Turn the engine OFF and set the ignition key to the LOCK position.
- Press and hold the power door lock button for about 3 seconds until the DIC displays the current RFA mode.
- Press and hold the reset stem for 2 seconds to view the next mode.
- Briefly press the reset stem to select the preferred mode, which will then clear the DIC display.
