Nj help!!!
Old Apr 4, 2024 | 10:40 AM
Njhummerh307's Avatar
Default Nj help!!!
Located in NJ. Had my 2007 H3 Since August 2023. Purchased with 45k miles … no serious issues at all. Just got a new tranny. Fresh tuneup and spark plugs… for some odd reason I can’t seem to find a mechanic that I could trust in New Jersey. Every time I bring it somewhere for regular maintenance or oil change, I leave with a problem that I never had.
Took it in for a regular oil change and leave with a broken tire rod.
Any advice, greatly appreciated & thank you in advance.
Old Apr 4, 2024 | 11:37 AM
What's a tune up on an H3? They have no distributor, your spark plugs are good for 100K miles doesn't matter how old they are. If you buy one and do not know the maintenance history you should change out all the fluids = Trans + Filter, T Case, Front & Rear Diffs, possibly brake fluid and coolant. Then you are done. If they put in any spark plug other than the AC Delco OEM Iridium plugs (or direct aftermarket substitutes) they will be eaten alive by the I5 High Intensity Coil on Plug Packs and cause issues in 10-20K miles.
H3s are like working on any GM truck, no super secret special stuff going on.
You change the oil when the OLMS tells you to which is about every 5-9K miles. Best thing to do is learn how to DIY then you never have to take it anywhere.
If you do not understand the basics, walking into a repair facility is like jumping in a shark tank with a cut. They smell the cash in your wallet and get to it. Me thinks you may be "over servicing" you vehicle. Like why a new Trans with less than 100K miles?
Old Apr 4, 2024 | 03:00 PM
wpage's Avatar
There are lots of places to go in NJ...
Any clues where to start? And like the man said. Whats the problem?
Old Apr 4, 2024 | 05:47 PM
"Tire rod broke"?
What broke? All 4 inner and outer >>>TIE rods are original factory assembly line installed on my '07 all still tight @94k miles and my 3 still drives straight, no hands required on the steering wheel! Yours broke on a lift? Not while driving and you're still alive to post BS.
Old Apr 5, 2024 | 09:23 AM
Alpha X's Avatar
We're all here for help, so maybe a more descriptive title with less exclamation points would serve you better. If I was trying to find a local shop for auto repairs, I'd investigate google reviews and get recommendations from people I trust about where they take their vehicles. Also, good luck with your new tranny. It's helpful to have a co-pilot for road trips.
Sundrop Addict
Feb 23, 2010 09:42 AM
dmurdock
Mar 9, 2008 10:40 AM
telcobilly
20
Jun 1, 2007 03:13 PM
steelcity
18
Aug 29, 2006 07:14 PM
jen813
May 5, 2006 02:07 PM
