New upper control arms
Old Sep 15, 2019 | 02:06 PM
Ejwins's Avatar
I replaced my front upper right side control arm with moog r-series about 6 months ago and so far so good. I think I got it on amazon for under $150 if I remember correctly.
Old Sep 15, 2019 | 02:58 PM
H3Luxembourg's Avatar
Btw, same alignment for H3's with front lift ( 2.5 " )by TB cranked right?
Old Sep 15, 2019 | 04:24 PM
Ride height does not influence the adjustments needed for a proper alignment. Camber should still be set at 0degrees to prevent uneven tire wear. A slight positive toe, (equal on both sides to center the steering wheel) and 3+degrees of caster, is to improve handling and ride control. Cross caster is to offset road crown, as opposed to offsetting camber that can cause uneven tire wear.
Btw, I've seen many alignment techs adjusting specs/variances on the alignment machine computer, to show the uneducated customers "all green".
You know the alignment specs and that is what you should expect when the alignment is completed. Get a printout and post your results.
Tire Tech Alignment
This is the most advanced system that I have used and very accurate: hawkeye
Old Sep 16, 2019 | 03:10 AM
Tire Tech Alignment
Thanks bro will get this.
jman1335
Mar 13, 2017 10:43 PM
skicranmore
Sep 24, 2014 08:36 AM
alengman
16
Apr 21, 2014 09:05 AM
Mcpousnret
Jan 21, 2014 12:21 PM
204H3T
May 17, 2013 09:13 PM
