New TPS installed
Old Apr 14, 2022 | 09:01 PM
HogTech's Avatar
Default New TPS installed
I installed a new throttle body with a new TPS on my 06 H3. I have done the 5 min idle time without touching the throttle and TPS rests at 29% while the peddle is at rest. I have watched it go to close and then move back to that position when ever I turn the key on and wait. Is there a way to manually teach the closed position to the computer? I noticed I can slowly open the throttle and when I hit about 60% it trips DTC060e and the truck goes into reduced power mode.
Old Apr 15, 2022 | 09:10 AM
Were the harness connections to the TB cleaned?
Five minutes is a minimum. Start it and let it idle for as long as it takes to figure it out, could be 15 minutes.
Old Apr 15, 2022 | 10:42 AM
HogTech's Avatar
Doc Olds
yes I cleaned that connector and even put electrical contact grease on it as well. Ok I will do that just let it run.
Old Apr 16, 2022 | 06:07 PM
Justinh's Avatar
What should abs TPS % be at idle?
Old Apr 16, 2022 | 06:55 PM
Old Apr 16, 2022 | 10:25 PM
HogTech's Avatar
Default Doc Olds
So I let it idle for about 40 min. When I started it up my scan tool said the TPS was at 12.9% and it stayed there the whole time. The idle was fluctuating between 650-700 the whole time as well. Took the truck out for a test drive and told my wife to drive it like normal we had made it about 1/2 a mile and these two codes tripped. P060E and P0121. This is the first time for the second code to pop up since I have been trying to fix this. The vehicle speed was 44 mph at 2419 RPM the TPS was at 40.0% when it entered the reduced power mode and turning off the traction control. I am about ready to pull my hair out. The pictures is what the codes are.
Old Apr 17, 2022 | 12:56 AM
tried cleaning out the throttle body with throttle body cleaner?
Old Apr 17, 2022 | 02:52 AM
HogTech's Avatar
No it’s a brand new throttle body
Old Apr 17, 2022 | 05:52 PM
What brand/part #?
Old Apr 17, 2022 | 08:44 PM
HogTech's Avatar
I don’t know the brand but the part number is 12568580. I got it off eBay and they didn’t have a brand name.
