New Alternator not Charging
Old Nov 2, 2025 | 07:23 AM
brothapig's Avatar
Default New Alternator not Charging
2007 Adventure 186,000 miles.
Charging light came on, after after verifying alternator was not outputting, I changed the alternator. New one is not charging. I verified the mega-fuse and wiring, and then I removed that fuse to isolate the new alternator from the battery. At idle, I was getting 3 volts off the alternator. Per a suggestion from another thread, I removed fuse 32 to force the GBCM to go to full charge. I was then reading less than 1 volt off the alternator.
Parts store cannot test the alternator out of the car, so I am just asking for a gut check. Seems that I received a bad unit from the store, but I don't want to miss something obvious either. Any experiences out there that are similar that turned out to be something other than the alternator?
Old Nov 2, 2025 | 08:32 AM
ski.dive's Avatar
You got a Bad new alternator, it happens frequently
Old Nov 3, 2025 | 08:55 AM
I bought and installed a brand new Alternator on Mom's Pontiac back in the day, it was deader than the dead old one I was replacing. Any electrical man made part can be defective, try another.
Old Nov 3, 2025 | 03:18 PM
brothapig's Avatar
That's the plan. I pulled the new one out again and ordered another new alternator that will hopefully be here by Wednesday. I'll get it changed out and hope that this one will work.
BTW I'm getting good at this alternator thing if anyone needs a hand
Old Nov 3, 2025 | 04:11 PM
Justinh's Avatar
We expect a full write-up with pics and video showing every step, required tools, tips&tricks, and shortcuts.
Old Nov 4, 2025 | 09:45 AM
While you are in there practicing H3 Alternator replacement, give the wiring a thorough inspection for frays, compromise, missing insulation that might cause a ground out etc...
H3s&VWs
Apr 10, 2025 06:36 PM
mccullek
Apr 2, 2025 05:17 PM
06H3803
Feb 21, 2021 07:30 PM
flynripped
Feb 8, 2019 01:06 PM
Kevin Lawson
Feb 19, 2013 11:03 AM
