Need help with rough idle
Old Mar 23, 2026 | 06:10 PM
  #31
Justinh's Avatar
VVT solenoid?
Old Mar 23, 2026 | 06:22 PM
  #32
NFS's Avatar
NFS
Originally Posted by Justinh
VVT solenoid?
I changed that too
Old Mar 23, 2026 | 06:52 PM
  #33
Your rough idle startup for few seconds=starving for AIR OR FUEL
Check the secondary air injection pump!
Old Mar 23, 2026 | 07:00 PM
  #34
NFS's Avatar
NFS
i don?t have that , my pcm is tuned and I don?t have secondary air pump. It?s been removed. I never had this issue before till now
Old Mar 28, 2026 | 06:23 PM
  #35
NFS's Avatar
NFS
Default Update
Is there a way to see if the vvt is working ? I unplugged it while the engine is running and I even started the engine without it being plugged and the engine ran fine and didn’t throw a code. I checked for exhaust desire and angle and it shows 0. Is that normal ?
thank you
Old Mar 28, 2026 | 06:44 PM
  #36
I think i found the issue but I really need help fixing it. So I think it’s the VVT not commanding. When I unplugged the VVT the engine didn’t run rougher and didn’t thro a code. I checked for power and I am getting power and ground is good but when I check the scanner it shows desired and angle for exhaust is 0. So does that mean my pcm is not commanding my vvt? And if so how can I fix that? I replaced the vvt but still no changes.
thank you
Old Mar 28, 2026 | 06:47 PM
  #37
NFS's Avatar
NFS
you know that doesn’t help! The pcm been tuned for years! Never had an issue! Now I am getting **** because it’s tuned! The only damn thing is tuned about it is pass lock disabled and that secondary air is removed nothing performance related or any of that
Old Mar 28, 2026 | 07:32 PM
  #38
that tune is failing.............
Old Mar 28, 2026 | 08:02 PM
  #39
NFS's Avatar
NFS
lol it doesn’t
Old Mar 28, 2026 | 11:09 PM
  #40
Spanovich008's Avatar
The secondary air injection pump only pumps air into the exhaust for emissions purposes, not the intake manifold, and only when the engine is cold as well. Surely this wouldn’t cause a rough idle, especially since the PCM would still be in Open Loop?
