Need Help on Error Codes
Old Mar 11, 2020 | 08:06 AM
CARdiac's Avatar
Default Need Help on Error Codes
I am really stumped and need some serious help. I keep getting a stabilitrac error (no ABS light or error). It is not when I first start the H3, it is after I drive. Could be a short distance or a long distance, but the error comes back with no rhyme or reason. It used to be an occasional thing, now it is every time I drive. The vehicle drives fine and I don't notice any shifting or performance issues, just able to spin back wheels in the rain when the light is on.
The first codes were:
C0329 Transfer case encoder circuit low
C0276 TCM communication performance
I replaced the encoder motor but still got the code:
C0276 TCM Communication performance
I took it to my mechanic and he got:
C0329 Encoder Circuit Low
U1017 Lost communication with engine control module
He cleared the codes and drove it and got:
C0276 Transmission control module communication performance
I am at a complete loss as to the cause. Please send help quickly!
Old Mar 11, 2020 | 09:07 AM
LOOK at the connections and wire harness to the encoder motor, clean the connector with CRC electrical contact cleaner.
You could have a Transfer Case Control Module (TCCM) going bad, having corroded connections, or frayed wiring harness to it. Inspect an clean those. If you decide to replace the TCCM, the H3 uses 2 different TCCMs depending upon which T case the vehicle has so make sure to get the right one. I would also check the connections to the T Case dash control buttons and clean those as well.
Easy stuff first.
Old Mar 11, 2020 | 04:09 PM
Gadawg1's Avatar
Yaw Sensor under the drivers seat?
Old Mar 11, 2020 | 04:14 PM
maybe start by cleaning your chassis grounds around the vehicle. and if you have not replaced your battery terminals do so with good quality ones.
Old Mar 12, 2020 | 02:30 AM
scoreh3's Avatar
X2 on battery terminals. Changing out the factory one to a good quality one fixes may issues.
Old Mar 12, 2020 | 10:02 AM
What year H3 are we talking about?????
Old Mar 25, 2020 | 05:18 PM
CARdiac's Avatar
Sorry for the delay in responding. There was the smallest amount of corrosion on two pegs of the transfer case control module. This is likely from a sunroof leak 5 years ago. WHen I opened up the module it looks like a tiny bit of moisture caused a small dot of corrosion...just enough to kill the unit.
wpage
Nov 8, 2019 10:39 PM
Dave P.
Jun 7, 2016 12:02 AM
mnorrick1
Apr 5, 2016 06:57 AM
Neptune262
Feb 19, 2012 02:49 PM
Kdog
Dec 14, 2011 11:19 AM
