Help decoding a couple codes please.
Old Dec 12, 2011 | 09:25 AM
Kdog's Avatar
Default Help decoding a couple codes please.
Current code cu631
History codes cu626, cu631, u1064
I'm going to fix the air suspension so you wont need to suggest that. Just guide me the best you can knowing that and the codes. Thanks.
Old Dec 12, 2011 | 06:31 PM
coachwesh2's Avatar
the u1064 code is a loss of communication with the dim. if you are near a auto zone they will scan your codes for free . i tried to look up the other codes with no luck. so i would go to them to get scanned for free. if all else fails i will have the codes by tomorrow night . we have a all data system that will give me the codes. so good luck with the auto zone thing.
Old Dec 12, 2011 | 08:20 PM
Kdog's Avatar
Advance and o'reilly's are here and I went to both. There scanners wont pull a chassis code so this is from a local guy who charged me 10 bucks. The dealers wanted 98 and 94. If you find out let me know. If all else fails, I will go to the dealer. I may have went today but they wanted me to make an appointment and I didn't see why I couldn't just pull in for them to take 5 minutes to plug it up and tell me. I guess so they can scare me into letting them repair it.
Also, if you are looking for codes starting with cu and don't see them, look for co. My handwriting was not too good trying to keep up with the guy spouting off codes. Thanks a bunch.
Old Dec 13, 2011 | 07:31 PM
Mark R's Avatar
Originally Posted by Kdog
Current code cu631
My Book says "OBII"
"CO631" RR Position Sensor Range / Performance
CO626...LR Position Sensor Range / Performance
U1064....Lost Cummunications with Body Multiple Conrtrol System
Old Dec 13, 2011 | 08:05 PM
Kdog's Avatar
Thanks Mark.
Old Dec 13, 2011 | 08:32 PM
coachwesh2's Avatar
thats what i got as well . after i changed it to co instead of cu lol. it seems you still have an air ride problem.
Old Dec 14, 2011 | 04:39 AM
Kdog's Avatar
Not trying to be a bother but now that we have the code co631, is that something you can adjust or is it something I have to replace? Is that the ride height sensor? Sorry for not knowing too much. My first h2 didn't have the air suspension.
Old Dec 14, 2011 | 11:19 AM
Mark R's Avatar
You could probably replace the sensor yourself ..but from what I understad from the dealer is that their is a special set up gauge to align the sensor for proper operation left and right.
It sets the factory height...so just bolting it on will not give you proper Left/right height setting with out the special gauge that they use. Those sensors talk to the air ride computer and the voltage setting is critical from the sensors.
After I got wacked in the bumper cap and spun around a few months back...part of the repair was a complete alignment and Air Ride recalibraition.
If you set it wrong you could end up with a ****-Eyed Rig And cause the compressor to over run ..burning it out.
mt2ut1
Jan 1, 2017 10:07 PM
Alex2012
Oct 5, 2012 12:18 AM
hobcog2000
Apr 25, 2012 07:16 AM
thumper104
Nov 19, 2011 04:42 PM
AlisoH3
Mar 16, 2008 09:07 AM
