After market radio/ factory amp
Old Mar 20, 2020 | 09:57 AM
Csw8rn's Avatar
Default After market radio/ factory amp
I had installed an after market Pioneer radio and a set of 10s with an aftermarket amp. It all works great but the new radio doesn't shut off the factory amp causing a 500 mA parasitic drain killing the battery in a couple of days. Pulling fuse #38 stops the drain but disables the factory speakers. Any ideas?
Old Mar 20, 2020 | 10:11 AM
Review your install. Which adapter did you use?
Old Mar 20, 2020 | 10:57 AM
Csw8rn's Avatar
Don't know because I had it installed where I bought the gear. Im going to visit them tomorrow
Old Mar 21, 2020 | 08:47 AM
Csw8rn's Avatar
They used a PAC brand adapter which seems pretty standard.
Old Mar 25, 2020 | 07:30 AM
ski.dive's Avatar
The people that installed your stereo 'wired something wrong'
***They probably hooked-up the amp. to a constant wire
Go back and have them change the Amp. wire from constant !
Old Mar 25, 2020 | 07:35 AM
Simple fix, install a toggle switch to the remote turn on wire for the amplifier.
Old Mar 25, 2020 | 08:11 PM
pac systems seem to be buggy. alot of complaints on them
Old Mar 26, 2020 | 08:12 AM
hummer_on_fumes's Avatar
I had a lot of issues with the PAC harness in both our Escalade (Pioneer head unit) and H2 (Kenwood head unit), causing random issues with the speakers etc. I went with the Metra harness and it solved all the problems. Look at some of the Amazon reviews for the PAC harness in GM vehicles, a lot of people have the same issue. I don't know if that's related to your amp causing a drain though, that sounds like they wired it wrong or it's defective
esfop319
Jan 21, 2020 03:59 PM
crazygn
Feb 12, 2013 07:47 PM
jeepzjgrrl
Mar 18, 2010 06:48 PM
morbius
Apr 6, 2008 10:30 PM
H3toy
May 30, 2007 09:31 PM
