After market radio/ factory amp
I had installed an after market Pioneer radio and a set of 10s with an aftermarket amp. It all works great but the new radio doesn't shut off the factory amp causing a 500 mA parasitic drain killing the battery in a couple of days. Pulling fuse #38 stops the drain but disables the factory speakers. Any ideas?
The people that installed your stereo 'wired something wrong'
***They probably hooked-up the amp. to a constant wire
Go back and have them change the Amp. wire from constant !
I had a lot of issues with the PAC harness in both our Escalade (Pioneer head unit) and H2 (Kenwood head unit), causing random issues with the speakers etc. I went with the Metra harness and it solved all the problems. Look at some of the Amazon reviews for the PAC harness in GM vehicles, a lot of people have the same issue. I don't know if that's related to your amp causing a drain though, that sounds like they wired it wrong or it's defective
crazygn
Feb 12, 2013 07:47 PM
jeepzjgrrl
Mar 18, 2010 06:48 PM
