Is my oil usage normal?
Old Oct 26, 2020 | 12:05 PM
Broken Halo's Avatar
Default Is my oil usage normal?
I have an '08 Alpha with 51,000 miles. I'm using approximately 1 quart oil per 2000 miles (5-W30 Mobil 1, no leaks). All city driving and no towing. Does that sound normal?
Old Oct 26, 2020 | 12:30 PM
My 09 Alpha doesn't use any oil between oil changes, stays full. I use Mobil 1 as well.
Old Oct 26, 2020 | 12:44 PM
How many miles on your Alpha Doc?
Old Oct 26, 2020 | 12:48 PM
check your PCV system? maybe its pulling more oil then it should? if it's excessive it might pool inside the intake plenum.
Old Oct 26, 2020 | 02:28 PM
wfturner's Avatar
Any smoke from exhaust at start up or under acceleration or deceleration ?
Old Oct 26, 2020 | 03:12 PM
Nope, nothing Wil. Just for the heck of it I called the Hummer Dealership Service Dept. and explained the situation in detail. He said that was perfectly normal, to use a quart every couple of thousand miles and even new vehicles can use that. Normally I would take what the dealer tells me with a grain of salt, but, then again, normally the dealer will tell you something that brings you in for service.
Just Googled and found this article....guess I'm safe.
https://www.cars.com/articles/how-mu...nd%20on%20whom
Old Oct 26, 2020 | 04:46 PM
wpage's Avatar
That does not sound right...
There is a problem. Any stains under where you park at nite?
Old Oct 26, 2020 | 05:39 PM
As I said: "No leaks"
Old Oct 26, 2020 | 06:33 PM
I'm not buying it! I just did my annual oil change a couple days ago, just under 2k miles since last change. All I do is pull the plug and filter and allow to drain in 2 separate pans, and walk away. After doing some yard work, I installed a new acd filter and drain plug, then refilled with exactly 6qts mobil1 full syn.=FULL
I emptied the old oil filter, and the drain pans, and filled 2 bottles with the used oil:
i have over 200k miles on mine and it does not consume oil.
