Moisture inside headlights front disassembled
Old Jun 6, 2022 | 07:11 PM
Default Moisture inside headlights front disassembled
My 3 caught the bug:::>condensation/water inside the headlights. I removed the HL assemblies and dried them out with my wife's hair drier, then resealed.
With the grill removed I noticed a lot of debris behind the bumper(packed full to the condenser)
I used a shop vac and compressed air to remove. Then noticed rust on the bumper, inside and out, and decided to go all in. Removed the bumper & cover, and pressure washed the front end along with the bumper cover. High speed wire brushing & sanding on the bumper, then 4 coats of primer/paint. Also touched up any surface rust spots on the front frame supports. During re-assembly I also cleaned/greased the connections/contacts, even though they were clean and working perfectly before.
Old Jun 7, 2022 | 02:49 PM
Slacker................... it is about time.
Old Jun 7, 2022 | 03:53 PM
Pfff... rust.... you have no idea what rust is.
try keeping your rig up north a while. you get custom speed holes in the bumpers
Old Jun 7, 2022 | 06:10 PM
Justinh's Avatar
And how did you reseal the headlights? Did any of the plastic break when you pulled them out?
Old Jun 9, 2022 | 04:59 PM
Cano's Avatar
Default Resealed HL Assembly?
X2.
I have the same problem and was about to replace the headlights...
Old Jun 9, 2022 | 05:09 PM
Cano's Avatar
Bugly
May 10, 2019 05:06 PM
Slawton
Feb 15, 2019 08:38 PM
hmer
31
Sep 12, 2014 06:00 AM
eleewhm
21
Nov 4, 2013 09:55 AM
006h3
May 6, 2009 10:21 AM
